05-02-2013, 08:02 AM | #21 |
Re: Question on trailering
Thanks
I bought mine at Tractor Supply, they have a large selection of styles and a variety of varying weight limits, all at reasonable prices. george |
05-02-2013, 10:23 AM | #22 |
I strap my cars in by cradling the four tires and tightening them to the floor. No straps touch metal and the cars stay very tight to the floor. I installed four "E" track pieces about 48" long to line up with Model A's. I have never had a problem and have tugged the trailer across the country several times.
05-02-2013, 10:52 AM | #23 |
I did consider using the E-track cradling approach, but rejected it for reasons only important to me I guess. It looks like pretty good system that obviously has served you well.
05-02-2013, 11:13 AM | #24 |
Gary, are those straps custom made to fit your tires?
05-02-2013, 11:55 AM | #25 |
On tying down, you could also run rachet straps thru the 4 wheels instead of to the axles. FWIW
Paul in CT |
05-02-2013, 06:00 PM | #26 |
I wrap masking tape around the ends after rolling them up. Then I wrap tape around this bundle and the straps that tie the rig down. Keeps all this stuff in place. Works great and you don't have the ends flying in the wind. Also I cross the straps but I also can see the reasons for not crossing. I also watch the straps while I travel to see if they look like they are loose and do stop often to check them (and for other reasons us older guys stop often). Nice looking trailer. Mine is almost the same and I like your idea of a box in front. That is the next purchase I need to get by the boss(wife).
Fred Kroon 1929 Std Coupe 1929 Huckster |
05-02-2013, 07:14 PM | #27 |
HF has a metal box made for trailers that is tapered and fits the toungue perfectly.
Bill Worden 1929 Roadster 1929 Briggs Town Sedan 1930 Closed Cab pickup Smith Motor Compressor 1951 Ford F1 High Desert Model A's |
05-02-2013, 08:35 PM | #28 |
Thanks, I noticed it on one of my times at HF. Now the problem is to get the wife in there sometime to admire it also so that it may be a doable thing to purchase. Maybe I can take her to a flower shop first to see what items she may get there so as to soften her up a bit.
05-02-2013, 11:42 PM | #29 |
1. The best place to get high quality straps is AW Direct (Towing equipment)
http://www.awdirect.com/ get 4 axle straps and 4 ratchet straps. Get good stuff, you don't want to lose your baby on the side of the road. 2. Never strap to the center of a front I-beam axle, you will bend it I guarantee it. One strap each side of the axle as far out to the wheel as possible. 3. Forker, you have a problem. As far as the rear of the trailer is concerned, the D rings should be way at the far corners of the trailer. I cannot tell about the front. With your present setup, if you hit even a moderate bump, the car can hop left and right and because there is little clearance between the car and the trailer on the sides you are in for trouble. I have seen this happen. You can either move the D-rings or cross the straps. I always cross the straps and never worry about breaking a strap since I use the highest quality from AW Direct 4. after you have driven about 5 miles get out and re-tension the straps, or at least check the tension. They tend to loosen a bit at first I would not run straps through the wheels; you will torque them and end up with some nasty run-out
'31 180A |
05-02-2013, 11:52 PM | #30 |
Charles, I took e track straps and had the additional pieces sewn to them. They will fit a variety of tire sizes including both 21" and 19".
05-03-2013, 01:47 AM | #31 |
quote""""tbirdtbird::::
3. Forker, you have a problem. As far as the rear of the trailer is concerned, the D rings should be way at the far corners of the trailer. I cannot tell about the front. With your present setup, if you hit even a moderate bump, the car can hop left and right and because there is little clearance between the car and the trailer on the sides you are in for trouble. I have seen this happen. You can either move the D-rings or cross the straps. """"quote""" i agree with tbirds observation on #3 and to add to that,, the design of the model A rear axle tube is it is larger in the center and narrows as it goes towards the backing plate. i always put the strap at the narrowest part on the axle (behind the backing plate) and out to the rings which should be straight out from that point or even a little more apart. the reason being if the strap slides a little outwards an the axle housing since the taper gets narrower it will loosen up... the front should be at the outer most points of the axle between the spring perches and the king pins and straight out to the rings or even a little more apart.. Last edited by Mitch//pa; 05-03-2013 at 06:53 AM. |
05-03-2013, 08:20 AM | #32 | |
When the handle is completely folded like this it is locked and cannot move. I get my straps from TSC. I have NEVER had an issue with one. I haul a lot of stuff significantly heavier than the A often. I have the HF tongue box on one of my trailers, spring for the bigger one, it is a much nicer unit for only a few bucks more. It is still cheap compared to the US made ones though.
1929 Model A Barn find. California car, just a few more parts to find. Interior, steering box (rebuild), and I am sure much more! |
05-03-2013, 08:38 AM | #33 |
29ModelA: Most high end car manuf suggest to run straps THRU the wheels if not using the wheel basket tie downs. FWIW
Paul in CT And if you tighten the straps thru the wheels without OVER tightening there shoukd be no problems. |
05-03-2013, 08:42 AM | #34 | |
05-03-2013, 08:43 AM | #35 | |
It has nothing to do with how tight the straps are. It has to do with the forces involved when the Model A shifts in a hard stop. It wouldn't take much to bend spokes, or the wheel for that matter. Edit: It appears that it is legal to do it, but you have to be careful not to put the strap too close to the 6 o'clock position or it will loosen quickly. I am actually surprised that is legal, I don't think we would ever get away with that hauling equipment.
1929 Model A Barn find. California car, just a few more parts to find. Interior, steering box (rebuild), and I am sure much more! Last edited by 29ModelA; 05-03-2013 at 08:50 AM. |
05-04-2013, 08:17 AM | #36 |
29Model:
you and I have hauled our fair share of heavy construction equipment, and I agree we would never get away with straps thru the wheels for that. It is a silly idea when you consider there are so many other much stronger places on a vehicle to get a good purchase on. Chains and load binders were our way of life. And we always crossed to avoid hop. And any vehicle can hop. It is not just forces front and rear. I saw a lot of mistakes out there, and they were never pretty.
'31 180A |
05-05-2013, 10:48 AM | #37 | |
Your point is well taken and thanks for raising that concern. The D-rings are welded in place between slats that the ramps rest in, which was the only place I think the trailer builder felt they could go (btw, the D-rings were at my request, not the location). I guess I will need to add additional straps to the far back corners or eliminate the use of the rear D-rings altogether. george |
05-05-2013, 02:30 PM | #38 |
One other simple thing to remember is to place your car far enough ahead on the trailer so you have enough weight on the hitch so that the hitch does not bounce up and down when you travel. But don't put to much weight on the hitch either. You will find this proper spot by some trial and error.
05-05-2013, 10:54 PM | #39 |
Fred is right on. Not sure how much length you have to the trailer to shift the car much either way but a good thing to be aware of. If you have the car too far back the trailer will fishtail like crazy. We've all seen guys trailering who were creeping because if they went any faster they'd fishtail. If the car is too far forward it will lift the front of the tow vehicle up in the air somewhat which will take weight off the front tires and your steering will go bonkers. You are usually trying to achieve about 150 pounds of tongue weight. A trailer builder should have known those D-rings were too close together. What is the spacing in the front?
'31 180A |
05-05-2013, 11:05 PM | #40 | |
When I trailered my T home (9 hours one way, part of it through the mountains in WV and PA), I used 4 large straps. Two from the front axle to the rear of the trailer, and two from the rear axle to the front of the trailer. Snugged them up good, and it stayed put all the way home. I stopped multiple times to check, but they were fine. |
Thread Tools | |
Display Modes | |
