Old 05-10-2019, 11:16 PM   #1
mrtexas
mrtexas's Avatar
Default 41 dual MC
Here is a corvette remote fill dual MC in my 41. Not much room for a standard dual MC.
This one could be piped on either side which is nice.
https://fordbarn.com/forum/picture.p...ictureid=41663
41 woodie https://41fordwoodie.weebly.com/
mrtexas is offline   Reply With Quote
Old 05-11-2019, 07:53 AM   #2
JSeery
JSeery's Avatar
Default Re: 41 dual MC
I can't get that link to work?
Old 05-11-2019, 08:51 AM   #3
51 MERC-CT
51 MERC-CT's Avatar
The link indicates that the image is in GIF format with just a 1x1 pixel resolution and may have to be converted to JPEG to publish in this forum.
If you magnify and look at the center of the black screen you can see the dot.
Old 05-11-2019, 09:32 AM   #4
Cool Hand Lurker
Cool Hand Lurker's Avatar
Well, it is a Chevy part.... maybe it is not meant to be...
Cool Hand Lurker is offline   Reply With Quote
Old 05-11-2019, 12:50 PM   #5
mrtexas
mrtexas's Avatar
Well, Chev, yes. It was very difficult to find a dual MC that would fit on the 41 and still have access to adding DOT 3.
Old 05-11-2019, 10:35 PM   #6
fordor41
fordor41's Avatar
I used a ford torino on mine with a chassis eng. adapter. it moved the access door back towards the seat but was still easy to fill the M/C.
fordor41 is offline   Reply With Quote
Old 05-12-2019, 08:38 PM   #7
40 Deluxe
Have you verified that this dual master cylinder will function as designed in the event of a failure (like a blown hose)? If the linkage from the pedal does not allow full design travel, you will be no better off than the original single master!
To test, crack open a bleeder screw on the front and see if the car still stops. Just push the pedal down once (like in a panic stop situation) and keep holding it down while an assistant closes the bleeder screw (this way you won't have to bleed the system). Repeat for the rear. If the car doesn't stop with two wheels, you have a problem!
Thread Tools
Display Modes
