Old 06-22-2019, 11:04 AM   #1
F.M.
Default Spark Plugs C-4 Take Apart With Green # and letters
I have a NOS set of Four and would like to know what they fit and when the Green color was used..Have not seen many that way..
F.M. is offline   Reply With Quote
Old 06-22-2019, 05:15 PM   #2
ursus
Default Re: Spark Plugs C-4 Take Apart With Green # and letters
Champion C-4 plugs were the replacement for the original 3-X plugs and for the Model-B. They were made over many years and in many iterations: black take-apart, non-take-apart, zinc coated, etc. I have some marked "Made in Canada".
Old 06-22-2019, 06:19 PM   #3
John Stone
John Stone's Avatar
Actually Model B’s used the 3X. C-4’s were for the early V-8’s.
John Stone is offline   Reply With Quote
Old 06-22-2019, 07:16 PM   #4
jw hash
jw hash's Avatar
John Stone is right on. the C-4`s can be used in the A`s an B`s but they are not correct for them. they do NOT go deep enough into the head. the 3X is the correct plug.
that is all I will run in my A`s.
jw hash is offline   Reply With Quote
Old 06-23-2019, 03:40 PM   #5
barnstuf
In 1932 Ford introduced a V8 engine and the C-4 spark plug was the official spark plug made for that engine and recommended by Ford.. The 3X was the official Ford Motor Company spark plug for both the Model A and Model B.
In 1933 the Ford V8 engine for that year and subsequent years did not use the C-4 and they would not fit.
Now suppose you operate a spark plug company who had thought Ford V8 would use the C 4 for a long time, and had produced large quantities of C 4 to meet the supposed demand.
Very likely what happened is that those C 4 plugs in the warehouse will fit the Model A and the Model B, and while not Ford recommended plug the heat range on them is close enough for satisfactory service so advertise them for aftermarket use on the A and the B. This is my guess as to the reason they were promoted as the aftermarket replacement spark plug.
barnstuf is offline   Reply With Quote
Old 06-23-2019, 04:06 PM   #6
noboD
I am interested if you want to get rid of them.
noboD is offline   Reply With Quote
Old 06-26-2019, 12:12 AM   #7
redmodelt
redmodelt's Avatar
I miss read the title and was thinking of Splitdorf which were green.
