02-16-2016, 09:17 AM | #1 |
Two Transmission Questions
I came across four flathead-era transmissions some months ago and had a couple questions about them.
1) One of the cases appears to be from 1932. Its serial number is 18-2439, which I’d assume means it’s a VERY early one. This case has no inspection plate; it’s just flat cast iron where the opening would normally be. All the other Ford transmissions of this era that I’ve seen have the little cover at the top that’s held on with two screws. Does the lack of an opening make this case special in any particular way? 2) I have a side-load transmission with the serial number 99A-231748. If I’m reading the charts correctly it should be a late 1941 Mercury box. My question is this: It came with a 15-tooth main drive gear. What model(s) does this apply to? I have Mac VanPelt’s transmission bible and in the back where he lists various part numbers only one type of main drive appears to have 15 teeth. This sounds unique, but is it? Thanks! |
02-16-2016, 10:11 AM | #2 |
Re: Two Transmission Questions
very low serial number indicating early 32 V8
15 tooth input shaft would be a commercial trans would have mated to a 29 tooth cluster. count the number of teeth on the cluster gear (lower shaft-end closest to input shaft) commercial trans would have been in a pick up, 1/2 ton panel, sedan delivery |
02-16-2016, 10:54 AM | #3 |
The side cover has a 4" sleeve for 2 nd and 3rd and if you can get a top cover with 4" fork. If little lower geared in first that's ok. This will NOT affect your top speed.
02-16-2016, 11:03 AM | #4 | |
As for the cluster (29-24-18 teeth), I can't find a part number on it. In the back of VanPelt's book it looks like it could be part number 022A-7113A, 022A-7113B or 21C-7113. Are these all interchangeable? Is there any way to positively identify which one it could be? |
02-16-2016, 02:59 PM | #5 |
the differences are in the thrust surface of the cluster gear, different thrust washers on the out put end and yes they all will work as long as you have the correct thrust washer
022 I think is the designate for 60 hp V8 21C would be commercial |
02-16-2016, 03:15 PM | #6 |
Mart. |
02-16-2016, 04:02 PM | #7 | |
Post a pic if you can, it would be interesting to see. Thanks Paul |
02-16-2016, 04:14 PM | #8 |
1. I always view '32 V8 transmissions as being special since they are different and would be a prize for someone restoring a '32 ... especially if their title showed 18-2439. Mart, the grease fittings I've seen were there to lube the throw out bearing.
2. 15 tooth MDGs with 29 tooth clusters are not unusual, and they are not just "commercial". In 1940 for example, they would appear in anything from the V8-60 to a pickup truck as well as passenger cars. If the buyer lived in hilly country, the lower 1st and 2nd gears would help. If he were a farmer, the same. A great application, even today, is when a 3.54 rear is installed, the 15/29 reduces the need for so much clutch slippage to get going and still gives a straight drive in 3rd. This latter application may explain why it was installed in a Mercury(99A) ... heavy car with 3.54. Good match.
"Remember that when it comes to intelligence, half of all of us are below average." Last edited by Hoop; 02-16-2016 at 04:21 PM. |
02-16-2016, 04:36 PM | #9 |
I had a good trawl through the pics on the computer and found these.
The serial number is 18-292xx Mart. |
02-16-2016, 04:43 PM | #10 |
Anybody have a 32 trans with serial number 18-24762? Would love to meet that person!
02-16-2016, 04:53 PM | #11 |
02-16-2016, 05:46 PM | #12 |
02-17-2016, 10:29 AM | #13 |
B&S, it's very possible that that guy with that transmission would like to meet you to get your frame .
FYI, Just got your recent PM and your request/interest in a part that I may have is so noted.
02-17-2016, 09:12 PM | #14 | |||
I'll have to keep the 15/29 combination in mind if I ever run across some nice 3.54 rear-end gears or if anyone else needs a transmission with lower first and intermediate ratios. What are the odds of this happening? Boy, I'd love to know! |
