10-04-2021, 09:20 AM | #1 |
Brake service rod
My front brake service rod is a straight rod that does not have the nub. Hence, the brake rod return spring serves only as a guide for the rod and does not act as a spring. Is this correct? Acceptable?
10-04-2021, 09:48 AM | #2 | ||
Re: Brake service rod
10-04-2021, 09:49 AM | #3 |
Ug!
10-04-2021, 10:15 AM | #4 |
Is it just the one, or, all of them ?
10-04-2021, 10:25 AM | #5 |
Both front brakes
10-04-2021, 11:28 AM | #6 |
What happened ? Does it look like someone ground them off or something ? |
10-04-2021, 11:32 AM | #7 |
The center of the nub is 17 1/2" from the center of the fixed end of the rod. I would think you could drill the threads out of a 5/16 nut, cut it half, weld the halves to the rod, and grind it to shape. Of greater concern is why there are no nubs in the first place?
10-04-2021, 11:35 AM | #8 | |
10-04-2021, 01:18 PM | #9 |
Somebody probably took a piece of threaded rod and made one for whatever reason.
"The more things change, the more they stay the same." |
10-05-2021, 08:43 AM | #10 |
You can buy originals from Berts. That nub is important.
