Old 09-30-2018, 05:00 PM   #1
Clem Clement
Clem Clement's Avatar
Default hard shifting
On the trip today to the Armed Forces Retirement Home in DC, my Cabbie had trouble shifting into both second and third. I had to stop on occasion to get the tranny into second. No previous trouble. Ball on shift lever rebuilt 10 years ago.
Clem Clement is offline   Reply With Quote
Old 09-30-2018, 07:32 PM   #2
Jim/GA
Jim/GA's Avatar
Default Re: hard shifting
Were the gears grinding really badly?
Or did it seem like the shifter was jamming up?
Jim Cannon
Former MAFCA Technical Director
"Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 09-30-2018, 08:13 PM   #3
Wick
Wick's Avatar
You haven't been pulling the shifter up and turning it around again have you? We told you about that.
The ball should still be OK after 10 years. So I would look at where the ball fits into the shift fork. The fork could be worn.
Wick is offline   Reply With Quote
Old 09-30-2018, 09:09 PM   #4
Clem Clement
Like the shifter is binding
Old 09-30-2018, 10:11 PM   #5
F.M.
Bent fork ??
F.M. is offline   Reply With Quote
Old 09-30-2018, 10:32 PM   #6
eagle
eagle's Avatar
Check tranny fluid.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 10-01-2018, 12:20 AM   #7
Tom Endy
Tom Endy's Avatar
A fellow club member was having difficulty shifting his newly acquired Model A that had been restored. The tower had also been restored. I gave him another tower and it solved his problem.
When I took his tower apart I Found a pair of reproduction forks that I have never seen before and are apparently new on the market. They look to be a rough casting instead of forged. The slots in the forks are not wide enough to accommodate the ball on the end of the shifter. This caused the ball to jam up. The shifter was also a new reproduction, however, the ball was the correct size.
The Tunnels through the forks are too small and caused one of them to crack. I would be very careful using these reproduction forks when restoring a tower. Stick with the time proven method of having the originals welded up and milled to the proper size.
Tom Endy
Tom Endy is online now   Reply With Quote
Old 10-01-2018, 09:07 AM   #8
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Don’t discount those detents. We had one where a repro bullet was too long and it and the spring bottomed out before the bullet cleared the notch.
Jacksonlll is offline   Reply With Quote
Old 10-08-2018, 08:08 PM   #9
Clem Clement
Tranny is now topped off. Tranny better
Old 10-09-2018, 08:25 AM   #10
Jim/GA
Jim/GA's Avatar
So, you are saying that the transmission was low on 600W oil? That was the problem?
Thanks for reporting back your findings. Many people do not tell us what they found.
Jim Cannon
Old 10-09-2018, 08:32 AM   #11
WHN
Try half 600w and half STP.
Also helps if you have minor dripping from transmission.
Some owners use just STP. Enjoy.
WHN is online now   Reply With Quote
Old 10-09-2018, 10:43 AM   #12
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
I KNOW I'm DANGEROUS, whin' I "think", but here I go: Minerva had VERY CRISP Detents & had to be shifted with a SLAP to her knob, with an OPEN PALM. MUCH like whin you correct your KIDS---LOL
I told my Daughter, "If I'd stayed SINGLE, we wouldn't be having this CONVERSATION"!!!
Bill Abusive
"THE ASSISTANT GURU OF STUFF"
Old 10-10-2018, 07:55 PM   #13
eagle
eagle's Avatar
I use Lucas oil stabilizer. Makes shifting slicker than seal poo on an ice floe. Also had a little howl with 600W, been gone for 4 years since I've changed to Lucas.
