10-29-2018, 11:31 AM | #1 |
Oil pump shield modification questions
I was going through my box of model a oil pumps to choose which one I was going to rebuild. And found one that someone previously had modified the outer pump baffle/shield. Is this something anyone here has seen done before. If so are there any benefits to performing this modification or it is it hurting the function. Ben
10-29-2018, 01:08 PM | #2 |
Re: Oil pump shield modification questions
It hurts function, raises the minimum oil level that can be pumped
10-30-2018, 10:34 AM | #3 |
Also more apt to 'aerate'. The shield is designed to force the pump to pick up oil from very low in the pan.
10-30-2018, 10:43 AM | #4 |
Perhaps modified due to reoccurring sludge in the bottom of the oil pan? Poor maintenance or crappy oil back in the day..
10-30-2018, 10:45 AM | #5 |
Thanks for the replies guys. That is what my thoughts were as well but thought I would ask since the motor was running when disassembled.
10-31-2018, 09:32 AM | #6 | |
10-31-2018, 11:43 AM | #7 |
Before I Disassembled it! Oops!
