Old 10-19-2018, 11:41 AM   #1
xmarine
xmarine's Avatar
Default quarter glass
Can anyone give me the dimensions for the quarter glass on a 1930 tudor.Got a broken window and no pattern for a new one.Don't really want to pull the other side if I can help it
xmarine is offline   Reply With Quote
Old 10-19-2018, 12:28 PM   #2
fundytides
fundytides's Avatar
Default Re: quarter glass
You could order the glass from Bratton's or if there is a good glass shop nearby take the car to them.
fundytides is offline   Reply With Quote
Old 10-19-2018, 03:19 PM   #3
xmarine
xmarine's Avatar
if I had the size I could have it cut without hauling car to them
Old 10-19-2018, 09:02 PM   #4
xmarine
xmarine's Avatar
Does no one have the glass out of their 30 sedan?If someone needs the sizes of 28-29 glass I will be glad to measure for them
Old 10-19-2018, 10:14 PM   #5
J Franklin
J Franklin's Avatar
If you want measure and make a drawing or tracing of the opening you wish to fill and cut that in cardboard. You can test fit and then cut from that pattern.
Old 10-20-2018, 08:27 AM   #6
fuzes45
try Vintage Glass Usa
860 872 0018
fuzes45 is offline   Reply With Quote
Old 10-20-2018, 02:09 PM   #7
Gary WA
Gary WA's Avatar
this work?
www.whidbeymodelaclub.com
Old 10-20-2018, 07:55 PM   #8
xmarine
xmarine's Avatar
Thank you!
Old 10-21-2018, 08:27 AM   #9
desotoguy
BTW, the 1/8"R at the lower left corner is "typical" for all four corners. Glass man may not realize that.
desotoguy is offline   Reply With Quote
