10-21-2018, 07:33 PM | #1 |
Strange Electrical Occurence
Washed car in driveway Friday.
Dried car off with a leaf blower. Drove back into garage. Decided to test headlights as I recently installed 50/32 bulbs. With engine running tried low & high beams. Ammeter showed significant discharge with each. Lights off ammeter still showed discharge. Tried again with same results. Turned car off. Waited about 1-2 minutes and restarted car. Tried lights and ammeter showed normal charge. Same with lights off. I run an alternator otherwise all is original. What could have caused this to happen? Thanks. |
10-21-2018, 07:49 PM | #2 |
Re: Strange Electrical Occurence
"Dried Car Off With A Leaf Blower" ???
Actually, I like that - |
10-21-2018, 08:29 PM | #3 |
Water in the headlight switch, wiring, etc.?
10-21-2018, 08:47 PM | #4 |
How much current, same as with headlights on or did the amps drop some with the lights off?
10-22-2018, 08:53 AM | #5 |
Is the ammeter needle sticking?
10-22-2018, 09:21 AM | #6 |
10-22-2018, 09:48 AM | #7 |
If its a self exciting alternator, you do have to rev the engine up for a second when you first start the car to get the alternator to kick in. After it does it should continue to charge even at an idle.
10-22-2018, 11:15 AM | #8 |
10-22-2018, 02:16 PM | #9 |
I agree with Katy... my ammeter will stick occasionally when I turn lights on. Just tap the dash firmly and it frees up.
10-22-2018, 06:32 PM | #10 |
Ammeter not sticking.
I did not think to check the headlight current. Leaf blower does an excellent job of getting the water out of tight spaces. Appreciate all the replies. Thanks! |
