06-18-2020, 05:44 PM | #1 |
how to retain Ford '35 pu shifter
Took out the shifter to get cab off, putting it back in, seems to be in the right place and shifts gears ok...but how does it stay in there?....I don't want to just pull it out by accident
Thanks Bob E. |
06-18-2020, 05:53 PM | #2 |
Re: how to retain Ford '35 pu shifter
Looks like you have maybe four parts missing. B-7227, B-7228, and maybe
B-7248 and B-7249 Last edited by Bob C; 06-18-2020 at 06:06 PM. |
06-18-2020, 06:07 PM | #3 |
Also missing B-7227 spring that fits underneath B-7228.
06-18-2020, 06:12 PM | #4 |
what about the alignment pin on the side?
06-18-2020, 08:18 PM | #5 |
Good point! Plus the leather washer.
06-18-2020, 08:41 PM | #6 |
06-18-2020, 08:49 PM | #7 |
06-18-2020, 09:02 PM | #8 |
from experience Charlie? I know I learned the hard way!
06-18-2020, 10:34 PM | #9 |
I think the parts are there...I know the little pin is there and in right...Let me do more checking and thinking...does the shifter stay in there by itself?
06-18-2020, 10:46 PM | #10 |
the top washer, 7228, is bigger than the hole in the screw on cover, 7220, so it can't come out with all its correct parts
06-19-2020, 12:33 AM | #11 |
From what i see the bottom washer is now on top of spring and top washer is either in the bottom or missing.
06-19-2020, 08:50 AM | #12 |
All the washers and spring go on first with the largest washer (7228) on top. Then the 7220 cap slides down the shift lever and screws on the tower (7222) thus holding all the washers and the spring in place.
