Old 07-28-2019, 03:36 AM   #1
56yblock
56yblock's Avatar
Default original paint y blocks
it's just a question, my 272 was painted in red but before it was green,i want to know if original built and what's year
56yblock is offline   Reply With Quote
Old 07-28-2019, 08:49 AM   #2
dmsfrr
dmsfrr's Avatar
Default Re: original paint y blocks
Here's a link to a chart of colors...
http://y-block.info/enginecolor.html
And another link, to help ID the engine block.
Scroll down to and click on the "BLOCK IDENTIFICATION" tab.
http://ford-y-block.com/technical.htm
dmsfrr is offline   Reply With Quote
Old 07-28-2019, 12:15 PM   #3
alt63bird
I have to find the file I've been compiling on engine colors, but if memory serves me correctly the green/turquoise/aqua color may have been used on '55 and maybe '56 Merc engines (I don't remember what CID), and there's a good chance that green color can be traced back to Merc flatheads from '52-'53, but again I need to find my research for a more-definitive answer. The same - or a similar - aqua/green color was also used on industrial engines and on '58 Ford 332s. The "red" you're looking for is more-correctly known as "Vermillion" and IIRC goes back to the early 1950s for usage.
The Y-block.com chart leaves a lot to be desired since it doesn't list Ford's M-numbers for colors to track what specific ones were used. In fact, it doesn't acknowledge the fact that from '59 through '65 Ford's gas engine long blocks for cars were painted semi-gloss black, with exception of some long blocks being painted aluminum for sale in Canada from '63-'65 as part of a tariff ID program. ID of the engines was done by the color of the air cleaner and valve covers during this period. Ford Corporate Blue was used company-wide for the entire engine assembly starting in Model Year 1966.
Alan H. Tast AIA, LEED AP BD+C
Technical Director/Past President-Editor-Publications Director, Vintage Thunderbird Club Int'l. (VTCI)
http://www.vintagethunderbirdclub.net
Author, "Thunderbird 1955-1966" & "Thunderbird 50 Years"
35+ year member, Crown Victoria Ass'n.
alt63bird is offline   Reply With Quote
Old 07-28-2019, 12:16 PM   #4
KULTULZ
KULTULZ's Avatar
Post Re: original paint y blocks
Being a FORD of CANADA model, it may have come through MERCURY GREEN.
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 07-28-2019, 05:07 PM   #5
darrell
if its ford of canada it will be dark green.all were that colour.
darrell is offline   Reply With Quote
Old 07-29-2019, 02:03 AM   #6
KULTULZ
KULTULZ's Avatar
Question Re: original paint y blocks
And then again, maybe not ...
- WHY IS IT ... -
Old 07-29-2019, 06:39 AM   #7
darrell
they were all green i seen and that was a lot but who knows.
Old 07-29-2019, 08:44 AM   #8
KULTULZ
KULTULZ's Avatar
I think MERC started the DARK GREEN in 1957. The 56 MERC was GOLD.
The CANADIAN FORD BROCHURE I showed might have shown a USA ILL.
And then again, what engine is actually in it?
- WHY IS IT ... -
Last edited by KULTULZ; 07-29-2019 at 08:52 AM. Reason: CRS - At The End of Life Stage
Old 07-29-2019, 09:19 AM   #9
raceron1120
raceron1120's Avatar
This is the Yblock I got, from a '55 Mercury, 292 cid. Block & heads are more gold-ish than yellow/green, valve covers cream/ivory with red letters. Supposedly had 17K miles, stored for years when I got it. Not sure if it was original paint but there was no indication of it having been repainted post-production. But lots can happen in 50+ years.
raceron1120 is offline   Reply With Quote
Old 07-29-2019, 09:21 AM   #10
darrell
the 272s were green just looked at one the other day.in the last couple of years i had a 57 292 and 312 both green.
Old 07-29-2019, 09:21 AM   #11
raceron1120
Closest color we could find to what was on the block when I got it. Can't remember what it is called.
Old 07-29-2019, 09:48 AM   #12
KULTULZ
KULTULZ's Avatar
Well ...
There is a member at the OTHER FORUM (oldcarmark) that has a 56 CANADIAN FORD.
For whatever reason, I cannot make a new post there or I would ask as he should know.
- WHY IS IT ... -
Old 07-29-2019, 10:25 AM   #13
scicala
scicala's Avatar
I wouldn't trust that Canadian brochure, especially since it shows a 1955 Engine. Sal
Old 07-29-2019, 10:45 AM   #14
raceron1120
Sal that engine above has the carb & intake you got from me a few years ago, not sure if the manifold was painted too. I got the block near Akron Ohio but don't know its origin.
Old 07-29-2019, 12:17 PM   #15
scicala
scicala's Avatar
Ron,
I still have the intake. I either sold the carb, or used it for parts. Don't remember. By the way, The picture you posted in the above post is 100% original in color and all parts I can see for a '55 Mercury. If it came from a Montclair, it's the 198 HP T-Bird 292 with 8.5:1 compression ratio. You can tell from the casting number on the heads if it's the standard 188 HP 292 in all '55 Mercury's (Except Montclair), or the 198 HP version from the Montclair.
And yes, the manifold was the same color as your pictured engine. My first car was a '55 Montclair original and untouched when I got it, with the same color engine.
Sal
Old 07-29-2019, 12:45 PM   #16
raceron1120
Ron,... You can tell from the casting number on the heads if it's the standard 188 HP 292 in all '55 Mercury's (Except Montclair), or the 198 HP version from the Montclair. And yes, the manifold was the same color as your pictured engine. My first car was a '55 Montclair original and untouched when I got it, with the same color engine. Sal
I still have the heads that came off the engine, ECZ's were used on the rebuild. I'll have to look at those old ones & see what the #s are on them.
Old 07-29-2019, 01:05 PM   #17
scicala
scicala's Avatar
Ron, '55 Mercury's with the standard 188 HP 292 engine should have come with ECK-A or ECL-A heads originally. The 198 HP Montclair 292 should have come with ECK-C, ECL-C or ECL-B heads originally.
The ECZ-? heads started in '56.
Sal
Old 07-29-2019, 02:07 PM   #18
raceron1120
The heads are ECK-B, according to the yblock tech page they are 55 TBird 292 cid. The heads used on the rebuild are ECZ-B or -C.
I have a room with a bunch of Yblock stuff including 2 or 3 assemblies. One complete motor is a 272, dark red almost burgundy/maroon color. Another is red, I think it's a 292 but didn't dig down to find the casting #s on it. 3rd one is a boat-anchor
'54 239, also red. Unknown if they are unmolested originals, or rebuilt/replacements.
Old 07-29-2019, 06:33 PM   #19
streetdreams
Location: Howell, Michigan, USA, The Peoples Slightly Overspent Demodependancy of Michigan
Ron, heads on your motor are ECZ-C heads.
streetdreams is offline   Reply With Quote
Old 07-29-2019, 07:22 PM   #20
scicala
scicala's Avatar
I guess they must have mixed it up in '55 with 292's. Or the info online isn't 100% accurate. Also possible the heads were swapped at one point, but with 17,000 original miles that's kind of unlikely.
Also, the ECZ - C heads were the best available in '56. Highest compression ratio.
'57 was another story.
Sal
