01-05-2016, 10:20 PM | #1 |
Window regulator mechanisms
Are there any ways of finding these parts for original regulators? They are at the end that attaches to the glass channel. One of the 4 coned washers turns, the rest are froze solid. Appears there were originally springs under them and they are pretty shot as well. Other than that, the regulators are in pretty good shape. What have you guys done?
Respecting and Resurrecting Ford Model A's. |
01-05-2016, 11:59 PM | #2 |
Re: Window regulator mechanisms
I usually use another less desirable regulator (like 4 door rears) as a donor for repair parts, or buy a better regulator and use the original as a donor for other regulator repair.
One thing to watch for; there were sometimes multiple OEM suppliers besides the aftermarket replacements, so sometimes the parts are different. For the same reason other make regulators such as Dodge and Plymouth may also have matching parts. |
01-06-2016, 12:04 AM | #3 |
Get in touch with Regulator Roy in New Jersey. Someone on here
may have his address. G.M.
www.fordcollector.com |
01-06-2016, 12:15 AM | #4 |
Here is Roy ..... Regulator Roy - Window Regulators (856) 478-2527 New Jersey. Happy cranking !
01-06-2016, 10:55 AM | #5 |
Just checked his web site and all he sells are NOS regulators. I really want to keep these, the price of 35-7 pickup regulators is pretty pricey. I know the easy way is to replace but I want to fix these. Has anybody repaired theirs?
01-06-2016, 11:31 AM | #6 |
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver |
01-06-2016, 11:35 AM | #7 |
The regulator it self is rusty. Soak it in vinegar for a few days. Brush it from time to time with a small metal Brissel brush. It will look like new in a few days. As said before get another regulator to get good parts of.
01-06-2016, 04:25 PM | #8 |
In the past, I bought a pair of NOS rear door regulators from Roy; and promptly used the springs, one winder gear and three of the track washers and springs to fix my early '35 coupe door regulators. Cheaper than one used driver's door regulator and I still have spare parts. Need to look at the big picture.
01-06-2016, 09:52 PM | #9 | |
To straighten the rollers I used a wrench, socket and hammer. The wrench is used as an anvil to straighten the roller edge. Once you get the rollers free you may be able to wind new springs around them. The repair kits I saw had a roller axel that is held in with a nut rather than swaged. Seems like they would eventually come loose. |
01-07-2016, 10:47 AM | #10 |
It only takes a little grinding on the back staking to drive those pins out, then fix or replace the springs and washers ( thats where other regulators come in handy ). Clamp them back in and spot weld the back of of the pin.
01-07-2016, 02:42 PM | #11 |
Would like to see a picture of the whole regulator I have two army foot lockers full of regulators,mostly Ford . I might have one.
01-07-2016, 07:21 PM | #12 |
Also you may want to check with Ray Helgers, he has quite a collection of them, and he is always reasonable. 401 635 4849, RI
01-07-2016, 11:27 PM | #13 | |
Depending on the price you were quoted for NOS 1935-37 Pickup window regulators, I sold my last pair of NOS for $150 pr, in 2016 I wouldn't call that pricey. I now only have one NOS passenger side. Although if you're 30 years old or younger with family obligations I would agree $75 for a window regulator could be expensive. Based on your photo that regulator looks to be scrap, someone on the FB would probably give you a cleaner used pair. The book shown is a copy of the hardware and trim book, it shows all the window regulators from Model A thru 1938, and a lot of other small parts. Available from all the repro dealers. I forgot to mention, in the second photo the piece of tape is pointing to a small notch that is unique to the 35-37 PU window regulator, the 1935 passenger car regulator looks similar with a much larger notch in that location. Last edited by nospartsman; 01-07-2016 at 11:43 PM. |
01-08-2016, 03:31 AM | #14 |
Has anyone tried the regulator repair kits from Then and Now Automotive (div. Of Antique Parts Cellar)?
I need new rollers etc fir the 32. Their kits look like they are NOS, and are $19.99. They came up top of google search. |
01-08-2016, 06:20 AM | #15 |
Yes the regulators travel through their full motion. They are not bent just have some rust on them. I would not call them scrap at all. I am in my 30's and do not make much money so whenever I can save money I try to.
01-08-2016, 08:57 AM | #16 |
I have a conv sedan, the regulators--and latches are less common than most, even though i patched up the gears ,winders and springs I didn't stop looking for NOS, i got the trim and hardware book so i would know what exactly I was looking for buying NOS in the 25--35$ range at Hershey, Ebay, -----then I sold the repaired and worn parts for more (the bidding got so high on one of the used parts it paid for all the NoS ones)
no matter how much you work on "fixing" a used regualtor or latch they won't work as smooth or effortlesly as a regreased NOS one |
01-08-2016, 10:09 AM | #17 | |
I did agree in my comment, that depending on your family situation a NOS $75 window regulator could be considered expensive. Window regulators and door latches are the two most used mechanical items after the drive train. Door latches lend themselves to repair, window regs not so easily. The teeth wear to a sharp point causing slippage, welding and reshaping each tooth falls into the category of "Pennywise and Pound foolish". My window regulator is not for sale, I'm not trying to sell my parts, in fact I offered to give you all the rollers you need for free and they're from NOS regulators. I hope your repair turns out good. |
01-08-2016, 07:14 PM | #18 |
Free is as cheap as it gets; very decent of you Nospartsman. Assuming I have this assembled correctly, (39PU), {I never laid eyes on one before 2 months ago and have never seen it assembled}, the roller appears to carry no weight. It looks to me that the stud simply skids along inside the track and the roller keeps it under spring tension so it does not fall out. So if Vanspeed's can be cleaned of rust sufficient for the stud and roller to be installed on the track, it ought to work. Given the corrosion on the spring, (and roller), replacement would not be a waste in my opinion, especially if they are free. A fine wire spring cannot afford to lose much cross section to corrosion.
01-08-2016, 08:58 PM | #19 | |
01-09-2016, 09:42 AM | #20 | |
If this is the correct installation, then Vanspeed's regulators are not necessarily beyond repair, at least at the roller end. |
Thread Tools | |
Display Modes | |
