05-10-2013, 10:45 PM | #1 |
Crack in Clutch Housing
Hey guys!
I started cleaning up my engine today with a wire brush and came across this crack in the clutch housing. Grandpa said he had the engine rebuilt in the 70's so it must have been done then I'm assuming. My main question is, should I begin looking for a replacement or will this get by just fine? You can see the washer was used to draw the bolt tight. Thanks in advanced! |
05-10-2013, 10:53 PM | #2 |
Re: Crack in Clutch Housing
Bashaw, I'd put a metal spacer behind the top of the washer, tighten it up, & DRIVE that dude. Happy motoring!!
Bill W.
05-10-2013, 10:57 PM | #3 |
05-10-2013, 10:59 PM | #4 | |
Bill has it right on!!!
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
05-10-2013, 11:16 PM | #5 |
I've had an issue like that on my peekup for six years (bought it that way) and have had no trouble. I'm with Bill. When you restore it or otherwise have to remove the bell housing, then you can replace it. They are easy to find and very inexpensive.
Ray Horton, Portland, OR As you go through life, keep your eye on the donut, not the hole. Last edited by 700rpm; 05-10-2013 at 11:52 PM. |
05-10-2013, 11:27 PM | #6 |
At some point in the future the car will likely need a new clutch, that would be a time to address the issue. Bell housings are easily found at swap meets for very little cost. Pick one up, bead blast and paint it, install a new pedal shaft, clutch release shaft and new bushings and have it ready to swap out the broken one. Tom Endy |
05-10-2013, 11:29 PM | #7 |
Hey, Ray, Dog here,
I like that, "PEEKUP" I'll call Ol' Bill's Dodge Kadota a "PEEKUP" just to IRRITATE him Buster T.
05-10-2013, 11:54 PM | #8 |
Good dog, Buster. Now go spot ol' Bill's tires.
05-11-2013, 12:38 AM | #9 |
Bill, Auburn swap meet June 19, you going? i would like to meet you
05-11-2013, 07:04 AM | #10 |
A new part might set you back $10. That if you can't find one for $5. But except during braking, the forces are primarily "forward." And during braking, the forces are "back" but limited by the coefficient of friction between your tires and road.
Washer sounds like it would work. Drive on. Joe K
Shudda kept the horse. |
05-11-2013, 09:49 AM | #11 |
I see no problems other than appearance. I have several AA bellhousings that are commonly used for the T-5, T-10 conversion that have the same issue. Usable as long as you don't mind using a washer on that hole. Rod
