Old 05-10-2013, 10:45 PM   #1
BashawT
Default Crack in Clutch Housing
Hey guys!
I started cleaning up my engine today with a wire brush and came across this crack in the clutch housing. Grandpa said he had the engine rebuilt in the 70's so it must have been done then I'm assuming.
My main question is, should I begin looking for a replacement or will this get by just fine? You can see the washer was used to draw the bolt tight.
Thanks in advanced!
BashawT is offline   Reply With Quote
Old 05-10-2013, 10:53 PM   #2
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Default Re: Crack in Clutch Housing
Bashaw, I'd put a metal spacer behind the top of the washer, tighten it up, & DRIVE that dude. Happy motoring!!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 05-10-2013, 10:57 PM   #3
BashawT
Bill W.
Thanks for the advice Bill!
Old 05-10-2013, 10:59 PM   #4
160B
160B's Avatar
Bill W.
Bill has it right on!!!
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 05-10-2013, 11:16 PM   #5
700rpm
700rpm's Avatar
I've had an issue like that on my peekup for six years (bought it that way) and have had no trouble. I'm with Bill. When you restore it or otherwise have to remove the bell housing, then you can replace it. They are easy to find and very inexpensive.
Ray Horton, Portland, OR
Old 05-10-2013, 11:27 PM   #6
Tom Endy
Tom Endy's Avatar
I wouldn't be too excited about it. It looks like it has been that way a long time. I don't see where it would cause any kind of failure.
At some point in the future the car will likely need a new clutch, that would be a time to address the issue. Bell housings are easily found at swap meets for very little cost. Pick one up, bead blast and paint it, install a new pedal shaft, clutch release shaft and new bushings and have it ready to swap out the broken one.
Tom Endy
Tom Endy is online now   Reply With Quote
Old 05-10-2013, 11:29 PM   #7
BILL WILLIAMSON
Hey, Ray, Dog here,
I like that, "PEEKUP" I'll call Ol' Bill's Dodge Kadota a "PEEKUP" just to IRRITATE him
Buster T.
Old 05-10-2013, 11:54 PM   #8
700rpm
700rpm's Avatar
Good dog, Buster. Now go spot ol' Bill's tires.
Old 05-11-2013, 12:38 AM   #9
ford3
Bill, Auburn swap meet June 19, you going? i would like to meet you
ford3 is offline   Reply With Quote
Old 05-11-2013, 07:04 AM   #10
Joe K
Joe K's Avatar
A new part might set you back $10. That if you can't find one for $5. But except during braking, the forces are primarily "forward." And during braking, the forces are "back" but limited by the coefficient of friction between your tires and road.
Washer sounds like it would work.
Drive on.
Joe K
Shudda kept the horse.
Old 05-11-2013, 09:49 AM   #11
Rowdy
I see no problems other than appearance. I have several AA bellhousings that are commonly used for the T-5, T-10 conversion that have the same issue. Usable as long as you don't mind using a washer on that hole. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
