12-16-2017, 08:18 AM | #21 |
Re: YIKES! Out of the clear blue, Vicky started leaking from radiator!
I would advise AGAINST pressure testing an 80+ yr old radiator, UNLESS it's at about 3-5 lbs. JMO FWIW
Paul in CT |
12-16-2017, 12:00 PM | #22 |
On a side note:
I once had a racing motorcycle that developed some liquid on the rim of the front wheel. I couldn't see where it came from, but in that area it could be brake fluid, fork oil, or coolant. I touch it, I sniff it, I ponder, I taste it. Oh, now I know. That's cat pee! |
12-16-2017, 12:41 PM | #23 |
You are right Paul, of course. That is what I stipulate when I take an A radiator to my shop. I should have made that clear.
