Old 02-17-2013, 12:02 PM   #1
Kevin - Illinois
Kevin - Illinois's Avatar
Default Distributor bolt
How tight does one tighten the distributor bolt on the side of the block?
Kevin - Illinois is offline   Reply With Quote
Old 02-17-2013, 12:43 PM   #2
redmodelt
redmodelt's Avatar
Default Re: Distributor bolt
Just tight enough to hold it in place. The pin should keep it from turning. Make sure the distributor is fully seated in the block. The screw fits in the groove in the distributor keeping it from moving up and down.
Old 02-17-2013, 01:29 PM   #3
figment
Don't forget the lock nut
figment is offline   Reply With Quote
Old 02-17-2013, 01:40 PM   #4
George Miller
George Miller's Avatar
There is no bolt on the side of the block. Are you talking about the one on the head. Is so just snug not real tight. To tight will bind the distributor shaft.
George Miller is offline   Reply With Quote
Old 02-17-2013, 09:36 PM   #5
Kevin - Illinois
Thanks everyone...
