Old 06-11-2015, 03:31 PM   #1
FrankWest
FrankWest's Avatar
Default cleaning and degreasing generator
I am cleaning and decreasing my generator in preparation for painting.
Started with commercial degreasers..did not work well!
Tried Lacquer thinner did not work too much better!
Maybe a Dremel tool with wire brush tool is the best?
Any suggestion? commercial pvc Pipe cleaner solution?
FrankWest is offline   Reply With Quote
Old 06-11-2015, 05:15 PM   #2
Russ/40
Russ/40's Avatar
Default Re: cleaning and degreasing generator
Lacquer thinner evaporates too fast. Use Mineral Spirits and a good stiff nylon bristle brush. Oh, and a lot of elbow grease.
Russ/40 is offline   Reply With Quote
Old 06-11-2015, 07:56 PM   #3
51 MERC-CT
51 MERC-CT's Avatar
If I'm just degreasing, a spray can of brake cleaner works well for me.
Sounds to me like you're trying to remove more than oil or grease.
Old 06-11-2015, 09:42 PM   #4
SofaKing
SofaKing's Avatar
The windings in generators and starters are insulated with a varnish that will dissolve when exposed to solvents like lacquer thinner. This will cause a short. You may want to exercise some care so as to prevent it from getting inside the unit.
SofaKing is offline   Reply With Quote
Old 06-11-2015, 11:20 PM   #5
dean333
dean333's Avatar
Send a message via Yahoo to dean333
I cleaned the generators on my 36 Fordoor and 57 Studebaker inside and out with mineral spirits. Worked fine for both.
Tim Carlig
dean333 is offline   Reply With Quote
Old 06-12-2015, 01:51 AM   #6
Tom Walker
Tom Walker's Avatar
You need more than a few weapons in the cleaning armoury don't you! Do you have any acetone? It sometimes shifts crud that nothing else will. When I have run out in the past, I have been caught stealing the wife's nail varnish remover....
Tom Walker is offline   Reply With Quote
