06-22-2020, 04:09 PM | #1 |
28/29 Brake Light Switch
I have purchased a new brake light switch from Snyder's for my 29. But, after reading many threads about defective repro switches, I am reluctant to install it. Is there any consensus on what the best repro switch is for 28/29? (I know, I used the word "consensus" ... which seems unlikely).
06-22-2020, 05:08 PM | #2 |
Re: 28/29 Brake Light Switch
The spendy one. $50.00. I think A&L makes them for the vendors. Love mine. (30-31)
06-22-2020, 05:11 PM | #3 |
A&L only does wholesale now. Call brattons or snyders and ask them for that one...
Mark Maron Ill., Region MARC & MAFCA MARC JSC Member MAFFI Trustee National Facebook Admin. https://www.facebook.com/groups/MARC.group/ A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
06-22-2020, 05:18 PM | #4 |
This video may help to make sure yours is ok.
https://www.youtube.com/watch?v=zsfWFf80Y70 |
06-22-2020, 05:32 PM | #5 |
The 28 & 29 types generally have less problems than the later 30/31. The problems are easier to repair as seen in the video.
06-22-2020, 06:07 PM | #6 |
06-23-2020, 08:52 AM | #7 |
06-23-2020, 11:02 AM | #8 |
Yes, your correct. Only the 30/31.
06-23-2020, 09:58 PM | #9 |
Get an original one anywhere you can. A&L probably makes a good one, but originals can sometimes be found for less than $10 at swap meets. I’ve given up on the repros. Too bad the Portland Swap Meet was cancelled this year.
06-24-2020, 09:18 AM | #10 |
Thank Ray. I think I will go on the hunt for an original.
06-24-2020, 11:10 PM | #11 |
You could try Tom at Model A Ford Works in Portland. He has a lot of original stuff. 503-410-1091.
06-24-2020, 11:19 PM | #12 |
The switches available from the vendors are no good on RHD cars. Does anybody know what the RHD switches looked like and how they were installed?
06-25-2020, 12:20 AM | #13 |
06-25-2020, 10:07 AM | #14 | |
Here you go. |
06-30-2020, 07:06 PM | #15 | |
The switch was installed on the right hand side chassis rail. The metal used is much thicker than the repro LHD switch. It is basically a flat plate with a half cylinder cover that is held in place with some small tabs. The spring inside is very strong. I can dig out some pics if you wish? Just let me know. My switch is off and early 28 Australian "Tourer" |
