Old 02-03-2020, 03:06 AM   #1
Red98
Default Powermaster alternator
I wish to purchase a Powermaster alternator for a 50 Merc flathead (the end of a 12v conversion).
Who has one mounted in front of a 4bbl Holley? I don't have that yet either and seem to recall the 4bbl mounts backwards on some intake manifolds for room.
I need verification the PM alternator isn't too long to fit. Also need to know the proper pulley diameter for proper charging.
And wonder about anything else I'm overlooking.
Thanks
Red98 is offline   Reply With Quote
Old 02-03-2020, 05:40 AM   #2
flatheadmurre
flatheadmurre's Avatar
Default Re: Powermaster alternator
They come in std and short versions.
Must be some drawings with dimension from Powermaster.
If i remember right the short clears a dual setup with margin...
Old 02-03-2020, 06:46 AM   #3
39portlander
39portlander's Avatar
Have you considered a Ford one wire alternator, the nice thing about these is a replacement can be found @ most all of the major parts stores nationwide.
Good luck and let us know how you make out.
39portlander is offline   Reply With Quote
Old 02-03-2020, 07:04 AM   #4
4dFord/SC
4dFord/SC's Avatar
Originally Posted by Red98 View Post
...seem to recall the 4bbl mounts backwards on some intake manifolds for room.
I think they're mounted backwards to line up with the stock accelerator linkage.
4dFord/SC is offline   Reply With Quote
Old 02-03-2020, 08:27 AM   #5
51 MERC-CT
51 MERC-CT's Avatar
The carb. does not really have a forwards or backwards, you could even mount it sideways if needed to work for the application.
Old 02-03-2020, 09:18 AM   #6
drolston
drolston's Avatar
If you are thinking of using the Powermaster that is made to look like a stock generator, think again. They squeezed a small car alternator into that generator-looking case. Mine burned out in 3000 miles. A local alternator shop found some parts that would fit and rebuilt it. We will see how long this version lasts.
Old 02-03-2020, 12:05 PM   #7
chiefdave
chiefdave's Avatar
Thanks
I put an Offy/Holley 390 combo on my '49 and there is a clearance issue. Went with a conventional one wire alt.
chiefdave is offline   Reply With Quote
Old 02-03-2020, 01:09 PM   #8
4dFord/SC
4dFord/SC's Avatar
Can't speak for the 8BA, but I used a 1" spacer to mount a Holley 390 on my '40 with a 221 cu. in.
Old 02-03-2020, 01:30 PM   #9
my4dv8
You can slice a small amount off the back of a long powermaster without affecting looks and not loose cooling slots.
my4dv8 is offline   Reply With Quote
Old 02-06-2020, 11:19 AM   #10
Automotive Stud
Automotive Stud's Avatar
I've had one on one of my cars since 2009. I had a problem one summer with a stuck brush, but powermaster repaired it and sent it back to me no charge. I drive my cars quite a bit also, so I would use them again.
That said, I learned about EJ Whitney generator/alternators from this forum, I've had one of theirs on another car since last summer. So far it works great and looks even more authentic than a powergen, so my vote would be to use one of them again. https://www.ejwhitneyco.com/automotive.html
Automotive Stud is offline   Reply With Quote
Old 02-06-2020, 08:58 PM   #11
4dFord/SC
4dFord/SC's Avatar
I've had a Whitney conversion on my car for 15 years with no problems.
Thread Tools
Display Modes
