Old 12-20-2017, 04:54 PM   #1
clay co 27
Default Body mfg
How can you tell who built the body for 1931 s\w town sedan, it has nameplate on firewall but not legible ? Thanks Carl
clay co 27 is offline   Reply With Quote
Old 12-20-2017, 05:44 PM   #2
Big hammer
Default Re: Body mfg
My late31 tudor's body number is in the cross member where the seats attach :-)
get a bigger hammer tap done
Old 12-20-2017, 06:24 PM   #3
Gary in MN
Gary in MN's Avatar
Hi Carl: Check out Ford Garage..... http://www.fordgarage.com/pages/murraybriggs.htm
I had a 160 C that had the same mark on the strap from the front door post to the fire wall. Gary in MN
Gary in MN is offline   Reply With Quote
Old 12-20-2017, 08:30 PM   #4
Gary WA
Gary WA's Avatar
Door windows- straight on top or curved? straight-Briggs,curved Murray Body!
www.whidbeymodelaclub.com
Old 12-20-2017, 09:35 PM   #5
Keith True
Keith True's Avatar
The curved/straight window thing doesn't apply to the slant windshield cars.The Briggs,Murray,and Ford built S/W parts were interchangeable.
Keith True is offline   Reply With Quote
Old 12-20-2017, 09:35 PM   #6
Gary in MN
Gary in MN's Avatar
Carl was talking about a slant windshield fordor, I thought the straight /Briggs and curved / Murray door windows was for the "straight windshield fordors". Gary in MN
Old 12-20-2017, 10:16 PM   #7
Randy in ca
Randy in ca's Avatar
Briggs apparently used only D-nuts while Murray used only clinched nuts for several sheet metal locations on these bodies. The firewall is an easy place to check. The locations on the firewall are where the speedometer cable clip attaches on the passenger inside, and where the clip for the wire loom from the generator attaches on the driver side near the terminal box. Also check for the Briggs "bug" logo on the lower passenger side cowl:
File Type: jpg Briggs logo on lower rt. cowl (1931 Slant Window).jpg (27.1 KB, 122 views)
Randy in ca is offline   Reply With Quote
Thread Tools
Display Modes
