Old 12-11-2010, 04:23 PM   #1
John Mc
John Mc's Avatar
Default What do these markings mean?
Hi, I think I know what I'm looking at here but please confirm. Right hand cylinder with the arrow pointing towards the front? Thanks in advance. I found this cylinder on the front left side of the truck.
John Mc
Crystal Lake, IL
'39 1/2 Ton Pickup
'56 Lincoln Capri Hardtop
'77 Lincoln Town Coupe
John Mc is offline   Reply With Quote
Old 12-11-2010, 05:17 PM   #2
Henry/Kokomo
Henry/Kokomo's Avatar
Default Re: What do these markings mean?
I think you're right, John. The larger bore of the cylinder goes with the longer brake shoe which faces forward - with the Lockheed style brakes. If I'm in error, I'm sure someone will say so.
Henry/Kokomo is offline   Reply With Quote
Old 12-11-2010, 10:16 PM   #3
Brian
Brian's Avatar
Correct! bleed nipple goes to top. Brian
Old 12-12-2010, 02:21 AM   #4
Flathead Fever
Flathead Fever's Avatar
I've never seen on when an arrow on it. Somebody tried to make the installation idiot proof and it still not work.
Old 12-12-2010, 10:01 AM   #5
John Mc
John Mc's Avatar
Thanks guys!
John Mc
Crystal Lake, IL
'39 1/2 Ton Pickup
Old 12-12-2010, 09:46 PM   #6
Dale Fairfax
I guess I'm confused-if we're indeed looking at the top of the cylinder; the large bore goes to the front, then this cylinder is mismarked. It SHOULD be on the left front.
Dale Fairfax is offline   Reply With Quote
Old 12-12-2010, 09:50 PM   #7
Fordors
Dale, don't forget that the wheel cylinder needs to be on the outboard side of the backing plate.
Fordors is offline   Reply With Quote
Old 12-13-2010, 05:30 AM   #8
Mart
Mart's Avatar
The markings look right to me.
Maybe the previous owner had to make an emergency repair and that was the only cylinder available there and then. It will work if fitted wrongly, just not as well as it should.
Mart.
Old 12-13-2010, 08:20 AM   #9
flat-v8
flat-v8's Avatar
I just finished converting mine from brake rods (mechanical) to hydro yesterday. My wheel cylinders did not have any arrows, here's pictures of Left & Right. Took quite awhile to bleed, had a leaking joint, fixed that, then adjusting shoes was a chore with the anchor bolt, early style on only one back plate, the other 3 were later style without the anchor's at bottom. My brakes are awesome now!
flat-v8 is offline   Reply With Quote
Old 12-13-2010, 01:59 PM   #10
Dale Fairfax
You"re correct-my visuallization powers were obviously out of the building.
Old 12-13-2010, 02:42 PM   #11
FRANK PKNY
FRANK PKNY's Avatar
Dale I did the same thing. Then refigured in my head the cylinder is a RH one for sure. Frank
FRANK PKNY is offline   Reply With Quote
