Old 09-07-2013, 09:17 AM   #1
Fred Hanks
Default gas gauge
Jus installed new gas tank & gauge and 3+ - gallons gas and have no movement on gauge , how does one test the gauge ? this is a '49 F-1 6volt sys.
Fred Hanks is offline   Reply With Quote
Old 09-07-2013, 11:53 AM   #2
G.M.
Default Re: gas gauge
Put more gas in it, your about to run out??? G.M.
www.fordcollector.com
Old 09-07-2013, 12:27 PM   #3
Kube
Kube's Avatar
If it's a new Drake sending unit, it is probably working like most of them ... very poorly.
Old 09-07-2013, 12:50 PM   #4
Old Henry
Old Henry's Avatar
Like G.M. said, My gauge reads empty when I've still got 3 gallons in it . . . until the other day when I ran out of gas before the gauge even got to E.
The way to test and adjust the sender is with it out of the tank. You measure the depth of the tank to get the maximum distance the float can travel. Then, with the gauge out of the tank but hooked up to the gauge wire and ground, you move the float through its maximum range while watching the gauge. Be sure that the bottom limit that you move the float to is no further from the sender than the maximum distance it can move. Otherwise, you'll get a false reading, i.e. the float may have the ability to move further down than the bottom of the tank. If the gauge only reads empty way down there you'll run out of gas. The main accuracy to be concerned about, of course, is that the gauge reads empty well before the float gets to the bottom of the range just so you have a little "reserve." To adjust the sender some have the provision to slide the float bar one way or another to adjust it or you can just bend the float rod until you get the gauge to read the way you want.
Prof. Henry (The Roaming Gnome)
"It is good to have an end to journey toward; but it is the journey that matters, in the end. *Ursula K. Le Guin in The Left Hand of Darkness
Old Henry is offline   Reply With Quote
Old 09-07-2013, 02:16 PM   #5
Roger/Sacramento
Roger/Sacramento's Avatar
I have a '41 pickup with an original tank and gauge. The tank was treated with a por 15 kit and a Drake sending unit was installed per the directions. it registers accurate. I only put a couple of gallons in the first time and the gauge did not register because the float was stuck on the bottom. I filled the tank and the float broke loose and has been fine ever since.
KIM KARDASHIAN ISN'T FLAT, BUT MY MOTOR IS.....
http://s818.photobucket.com/home/roglehr/index
Roger/Sacramento is offline   Reply With Quote
Old 09-07-2013, 02:54 PM   #6
46fordnut
46fordnut's Avatar
depends on what unit.. i used one for a 6 volt mercury...did not work . found was a bad power connection in sender, bent the little tab inside works fine now. i have a 1946 ford .
if rust were money i would be a billionaire!!
46fordnut is offline   Reply With Quote
Old 09-08-2013, 11:31 AM   #7
Fred Hanks
How do I check to see if the gas gauge is ok???
Old 09-08-2013, 11:39 AM   #8
Old Henry
Old Henry's Avatar
You can ground the sender side of the gauge just momentarily and see if it goes to full. If so it's good but don't leave grounded too long or it could burn it out.
