Old 08-11-2010, 02:56 PM   #1
Bruce_MO
Default pinstripe paint removal while wet
I'll be masking and striping my "A" with One-Shot paint shortly, and I was wondering what solvent I would use if I had to clean up a mistake and start over. The car is painted with acrylic enamel w/ hardener.
Would I use enamel reducer? mineral spirits? I don't want to mess up my base color. Thanks for your advice.
Bruce_MO is offline   Reply With Quote
Old 08-11-2010, 03:08 PM   #2
Craig Lewis
Craig Lewis's Avatar
Default Re: pinstripe paint removal while wet
Mineral spirits would be perfect.
Alternatively, turpentine or a mild "final wipe solvent" (used just before spray painting) such as Proform PF603.
None of these will effect cured automotive paint as a wipe.
Craig Lewis is offline   Reply With Quote
Old 08-11-2010, 04:25 PM   #3
Bruce_MO
Thanks for your insights. I appreciate it!
Old 08-11-2010, 04:32 PM   #4
Doug in NJ
Doug in NJ's Avatar
Whatever you decide to use, test it first: Put some one-shot paint on something, let it dry a few minutes, and see if you can remove it. If you have anything lying around that was painted with the enamel (discarded used masking tape?), you could also check that the solvent won't mess it up.
Doug
My '31 S/W sedan project:http://31ford.dougbraun.com
My restoration diary: http://dougbraun.com/blog
Doug in NJ is offline   Reply With Quote
Old 08-11-2010, 05:12 PM   #5
Craig Lewis
The following doesn't apply to your situation, but...One shot lettering enamel can be removed years later with East Off oven cleaner. I learned this from a sign painter.
**DON'T DO THIS with your fresh paint job
....but I've used easy off to get the company lettering off my truck after 5 years and it softens up in a minute, then you can peel it off with a credit card.
Reasonable care should be taken to get it off the paint work in a few minutes.
I hand waxed it afterwards and the original paint looked fine.
Old 08-11-2010, 09:22 PM   #6
1929closed cab
Right... on the oven cleaner...One of my best freinds is an old pinstripe r ...and that's what he has used all his life...told me he was taught that from a guy who stripped cars at the factory.
1929closed cab is offline   Reply With Quote
Old 08-12-2010, 04:12 AM   #7
davis57ford
davis57ford's Avatar
Not trying to be an ashole. But if u r gonna stripe it yourself, and u dont know what to use to remove a screw up maybe u shouldnt do it yourself, let a pro striper do it then u dont have to worry about messing up, u get what u pay for!
davis57ford is offline   Reply With Quote
Old 08-12-2010, 05:51 AM   #8
Al NJ
Since you guys mentioned Easy-Off, I'll tell you that it works well MOST of the time but I removed lettering from a truck once and it stained the factory paint. I would test every time!
Al NJ is offline   Reply With Quote
Old 08-12-2010, 06:54 AM   #9
Gary/IA
Gary/IA's Avatar
Bruce, I don't know you but I am betting you can do it just fine. Take your time, do your homework (as you are doing here), and proceed. I have seen some beautiful paint jobs done by beginners. Remember, even the "Pro" had to do his 1st job.
Gary/IA is offline   Reply With Quote
Old 08-12-2010, 07:32 AM   #10
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
While I definitely feel like your advice has wisdom, generally speaking, most pinstripers I know have practiced a long time striping everything in their eyeseight that was junk (walls, refridgerators, mirrors, windows, etc.) BEFORE they embarqued on striping something that had value. THAT may be a topic for another thread but it sure seems like many folks now seem to want to by-pass the 'practice & learn first' stages and just move to the front of the line with expectations of it coming out perfect.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 08-12-2010, 10:06 AM   #11
james hitchcock
james hitchcock's Avatar
If it were me I'd opt for the professional. When I was younger I did the masking and sprayed on the stripe. I was never happy with the flow of the line and hated the edge caused by masking. I did one time get the roll of stick on striping at Pep Boys so I could see what pattern I wanted. It looked so good I left it on when my appointment was canceled at the paint shop. a year later when I did decide to remove it , it came off very clean.
James.
james hitchcock is offline   Reply With Quote
Old 08-12-2010, 12:58 PM   #12
Gary/IA
Gary/IA's Avatar
James.
A method of striping that worked well for me is as follows: I masked around the belt rail and then painted the entire belt rail the color of the pin stripe, I then applied a thin vinyl masking tape where I wanted the stripe. I then painted over this with the belt rail color (all thin coats) and then removed the thin strip of tape. There was my pin stripe. I then applied my clear coat. Just don't pile on the paint and you will have a very nice even sharp pin stripe. Just another way of doing it when you get to old and shaky to do it by hand.
Old 08-12-2010, 10:17 PM   #13
Jim Parker Toronto
Jim Parker Toronto's Avatar
Bruce, go ahead and try it, its your car. Even in French Lick they were showing the kids how to do it. Everyone has to start somewhere, and on your own car is a good place to learn. I am sure that whatever you do, you will be proud of it! Never mind mind all the negative comments above, its your car, not his!
Jim Parker Toronto is offline   Reply With Quote
Old 08-13-2010, 12:30 AM   #14
james hitchcock
I didn't notice any negative comments, just suggestions. All have tried different things and I would never tell anyone what to do or not do with his A. I certainly don't go by the book. I go to the Barn for suggestions, nothing says I have to listen to any of them. Enjoy your car.
James.
Old 08-13-2010, 06:45 AM   #15
Steve Miller
Steve Miller's Avatar
Anybody ever use a Beugler pin striping tool to stripe?
Thanks
Steve Miller is offline   Reply With Quote
Old 08-13-2010, 01:00 PM   #16
Aerocraft
Aerocraft's Avatar
Yes, the tool has worked very well for me. It was fairly easy to learn how to use it although I striped a lot of scrap first. I use One Shot. Have done a number of members cars, even one that went through fine point without any known deductions. It is fun to use. There is a bit of a trick to get the paint to flow out and not have "serrated" edges. Once that was mastered, my friends and I have been very pleased with the results. Gar Williams
Aerocraft is offline   Reply With Quote
Old 08-14-2010, 12:20 AM   #17
29RPU
29RPU's Avatar
I don't know, but I sure wouldn't suggest masking for a pinstripe. It' not a negative comment, no more than someone asking how to clean an icepick after digging a trench. Wouldn't you steer them towards a shovel, or equipment? Masking is far too difficult to get a straight line, much less a line that is even in thickness without jagged edges IMO. I'm a do-it-myself kind of guy, but I would suggest that Bruce get one of those stripers that has the little adjustable arm that you can use as a guide....I think it is a roller of some sort. Maybe that is what was mentioned above, I don't know what they are called. That should give a nice, even line, and if you follow a bodyline carefully, it should be straight.
If I had started this post, I'd want all the input possible before I started and I'd want to know what has worked and has NOT worked for people. Don't worry, Bruce will make up his own mind and do what he wants. As for me, I'll keep the negative comments coming if I think it might help somebody.
29RPU is offline   Reply With Quote
Old 08-14-2010, 08:56 AM   #18
Aerocraft
Aerocraft's Avatar
The tool is a "Buegler" paint pinstriping tool "made since 1934". I have seen footage of Ford production line pinstriping where it appears that the striper is using a tool very similar to the picture I have attached. As purchased, the tool came with a number of different sized wheels. They are also made with dual wheels where you can lay down two stripes at once. Hopefully, the picture shows enough detail to see the magnetic plastic strip that is used as a guide for the arm attached to the tool. As I recall, it was just over $100 for the tool and accessories. It has worked well for me. Gar Williams
Thread Tools
Display Modes
