Old 07-13-2020, 01:09 AM   #1
vilanar
Default 1957 Country Sedan front brakes
Hi guys,
I bet someone can educate me.
Im checking over new to me 57 Country Sedan , witch has "brakes overhauled"
Lines are new and internals look new also , but at front I can see linings between the drum and backing plate.
I measured that brake drum should go inwards 5/8 to be at right depth.
Bearings and races are properly assembled.
Question is are there drums with different "dish". Width of the drum looks to be right or have they changed wrong hub or maybe wrong hub and drum.
Work has been done while ago , so I can't say which part is new and which isn't.
Car has sit still in the carport years after that.
I did check Macs , Kanter and others but info is very limited.
Thanks,
Ari
vilanar is offline   Reply With Quote
Old 07-13-2020, 08:14 AM   #2
streetdreams
Location: Howell, Michigan, USA, The Peoples Slightly Overspent Demodependancy of Michigan
Default Re: 1957 Country Sedan front brakes
does drum rotate or are shoes rubbing drum on inside keeping drum from rotating?
streetdreams is offline   Reply With Quote
Old 07-13-2020, 08:36 AM   #3
vilanar
Yes, they rotate and brakes work.
Old 07-13-2020, 07:54 PM   #4
paul2748
paul2748's Avatar
If you have a shop manual, it should say what size the front brakes are. Then check the drum to see if it is wide enough to fit the shoe width. Wagons typically had larger brakes, maybe someone one put sedan drums on. Drums typically were swedged on the hub for those years.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 07-14-2020, 08:17 AM   #5
vilanar
Regarding to shop manual , shoes and drums are right width... but they are same in so many years. Maybe there is different dimension hubs on some models/years.
I just hoped that someone has tinkered with these and rememberes what is right and what is wrong.
Old 07-14-2020, 03:51 PM   #6
paul2748
paul2748's Avatar
The only possibility I see is the inner bearing is not the correct one, preventing the hub to go all the way on????.
The other possibility is you have the wrong backing plates???
Does the spindle nut seem to be correct when the hub is tightened up?
Pull the hub - put some clay or similar material on the spindle, put the hub on and tighten up. The pull the hub off and see what you have
Let us know what you find
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 07-16-2020, 07:11 AM   #7
bobss396
bobss396's Avatar
So the brake shoes may have a step worn in them? Probably has an odd-ball set of drums and hubs on it, any idea where they came from?
bobss396 is offline   Reply With Quote
Old 07-22-2020, 10:34 AM   #8
vilanar
Shoes are new and drums are turned and they match widthwise(contact area). Hubs go all the way like they should , that is why I asked if there is different "offset" drums.Looks like backing plates are original so I'm leaning towards that hubs are wrong.
