Old 10-07-2015, 08:32 AM   #1
HC&ME
Default 40 Ford Heater
Looking for a working 1940 Heater ! Please let me know if you know where I can find one.
Thanks for the help! Michele
HC&ME is offline   Reply With Quote
Old 10-07-2015, 08:58 AM   #2
TJ
TJ's Avatar
Default Re: 40 Ford Heater
Are you looking for the hot air type or the hot water type?
TJ is online now   Reply With Quote
Old 10-07-2015, 06:27 PM   #3
Joe Immler
Try Larry Caplan 19401 Clymer St. Northridge, Ca. 91326 818 366 9178 He may have what you want. He works on heaters and has a good supply. It has been some years since I dealt with him but he did good work.
Let me know if tou contact him.
Joe Immler is offline   Reply With Quote
Old 10-08-2015, 12:25 AM   #4
swoopNZ
If it's a 39/40 hot water heater you are after make sure it only has the 2 doors.
3 doors are for the later model cars.
Both they and the hot air models come up on ebay from time to time.
Prices for both types seem to run around $300 - $450.
There are a lot more parts to the hot air heater.
swoopNZ is offline   Reply With Quote
Old 10-10-2015, 09:49 PM   #5
Ron Engen
Smile Re: 40 Ford Heater
I will sell you one. 200 plus shipping. Ron ronengen@cox.net
Ron Engen is offline   Reply With Quote
Old 10-11-2015, 03:17 PM   #6
Newc
Newc's Avatar
Hi all; Remember the swtich and wiring! Also the motor has to work in all modes. Newc
Old 10-11-2015, 03:30 PM   #7
39topless
Ditto! Without the switch, you got nothin'.
39topless is offline   Reply With Quote
Old 10-12-2015, 05:48 AM   #8
clydemc
Have a 46 heater 2 door need little work $75 call 606 476 8035
clydemc is offline   Reply With Quote
Old 10-12-2015, 07:16 AM   #9
jacob smith
jacob smith's Avatar
flintstone has a 40 heater listed in the swap meet for sale. Also has a good photo of the heater.
jacob
Ford
jacob smith is offline   Reply With Quote
Old 11-07-2015, 11:14 AM   #10
dixiedelux
dixiedelux's Avatar
Where is the stock mounting position for a 40 ford hot-water heater in a Tudor Deluxe?
dixiedelux is offline   Reply With Quote
Old 11-07-2015, 02:10 PM   #11
40 FourDrDlx
40 FourDrDlx's Avatar
Here's a picture. I have copies of the template if anyone needs one.
40 FourDrDlx is offline   Reply With Quote
Old 11-07-2015, 02:34 PM   #12
JSeery
JSeery's Avatar
Nice template.
Old 11-07-2015, 05:49 PM   #13
dixiedelux
dixiedelux's Avatar
Thanks! That is the place where my 46 heater is. My 40 does not have a heater but the previous owner put the fuse box where the heater belongs. What I have for the Fordy is a Zephyr model Tropic Aire. Is there templates to be had for that heater. And does anyone have info of the Tropic Aire being used in a 40? MY 46 circulates through the driver side bottom radiator hose and the passenger side head. Is a stock 40 Ford set-up like this?
Old 11-07-2015, 07:58 PM   #14
Marv
Marv's Avatar
Make your own template out of card board. I used the very Tropic air heater you have in a 46 Ford. It in my opinion Tropic Air is a better heater than a normal one that they put into Fords. Much better defroster.
Marv is offline   Reply With Quote
Old 11-07-2015, 08:58 PM   #15
Charlie Stephens
I would suggest starting with a copy of "The 1940 Ford Book" from the Early Ford V8 Club https://www.earlyfordv8.org/store-pr...fm?id=19&pid=2 so you can identify the correct original heater. If you just want an aftermarket heater from that era that works it will probably be cheaper. Place an ad in the wanted section, here and on the Early Ford V8 Club Site (http://www.earlyfordv8.org). It might be nice to include a picture (from google or EBAY) of the heater you want. A picture will let you catch the guys with old heaters that have no idea what they fit. Good luck.
Charlie Stephens
Old 11-07-2015, 09:02 PM   #16
dixiedelux
dixiedelux's Avatar
That is good news Marv. I was wondering about the defrosters. I don't believe my 40 has defroster vents. The heater has a manually operated door on the left side, near the top, I presumed to be the defroster. How many speeds does the blower motor have on your unit. I have no switch for this unit. Can you advise me on that issue?
Old 11-07-2015, 09:53 PM   #17
bjk2dr
Would be interested in purchasing one of your '40 heater templates. How can I get one?
Thanks
Ken
bjk2dr is offline   Reply With Quote
Old 11-08-2015, 12:27 AM   #18
40 FourDrDlx
Thanks
Ken
Ken, just pm me your address & I'll mail one.
Bob
Old 11-08-2015, 11:04 AM   #19
bjk2dr
Thank You for your offer.
Ken Bednar
5568 HWY 175
Hartford WI 53027
( I think this what you meant by "pm") I don't use this site much & still learning. Plus being 73 doesn't help. Let me know if I should do something different.
Old 11-08-2015, 11:22 AM   #20
39topless
Ken Bednar
5568 HWY 175
Hartford WI 53027
Only 73? You're a youngster on this site. PM stands for "private message". It's a way for members to contact other members on a one to one basis. If you click on a members name, a menu will appear and on item is' "send a private message". Click on that and you're in business. When the member responds your "private message " alert located near the top right will appear in red. Click on that and you will access his message. Good luck.
Phil
