Old 12-10-2017, 08:50 PM   #1
bucket-o-rust
Default Distributor questions
What is the insulating washer on the condenser used for and is it needed. I hace two distributors one with a two piece shaft and one with a one piece shaft. Is one better than the other and why?
bucket-o-rust is offline   Reply With Quote
Old 12-10-2017, 09:31 PM   #2
Brentwood Bob
Default Re: Distributor questions
2 piece shaft
Washer goes on back of condenser to attach to lowerplate of distributor.
See diagram on page 79of brattons catalog.
Brentwood Bob is offline   Reply With Quote
Old 12-10-2017, 10:38 PM   #3
CWPASADENA
CWPASADENA's Avatar
I like the 2 piece shaft. This arrangement allows for some misalignment without adding extra load to the distributor bushings.
My opinion,
Chris W.
CWPASADENA is offline   Reply With Quote
Old 12-11-2017, 10:35 AM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
Without the thick insulating washer, the metal contact strap could get pushed to the cast housing and short out.
The washer also provides a stop for the original black filler stuck in the hole.
Most important, is the screw can bottom out and spin the condenser terminal without the washer.
