Old 12-10-2017, 06:16 PM   #1
pgerhardt
pgerhardt's Avatar
Default "What the h*ll is that!"
As I sometimes do I put in a minimum bid in a "grab bag" of model A parts on E-Bay, and won! I got some good model A parts, and some stuff I could not identify. I thought I would put it out there to see if you know what they are. Pictures of the parts (along with one of Steve Martin) are below:
BTW the item that looks like a grease cup has no through hole to the part that looks like a bearing or bushing. Yes confusing!
pgerhardt is offline   Reply With Quote
Old 12-10-2017, 06:20 PM   #2
Clem Clement
Clem Clement's Avatar
Default Re: "What the h*ll is that!"
Bottom two are Bendix parts. Upper right looks like the dipstick of a '27 gadooink roadster sedan. Center are twist-in grease caps
Clem Clement is offline   Reply With Quote
Old 12-10-2017, 06:48 PM   #3
foxfire42
foxfire42's Avatar
The last photo looks like a cam shaft nut
foxfire42 is offline   Reply With Quote
Old 12-10-2017, 06:53 PM   #4
foxfire42
foxfire42's Avatar
The photo with the grease cup almost looks like someone tried to make a way to grease the service brake cross shaft bushing. I can't see how the grease cup would clear the bracket. Also I think this is someone's idea that didn't get finished ie: no through hole for the grease. If you look up the Service brake repair bushing parts it will make sense. The grease cup is not part of the repair kit.
Old 12-10-2017, 07:04 PM   #5
pgerhardt
pgerhardt's Avatar
To those who guessed grease cups notice that there is no through hole from where it cup screws on, and no where for grease to go??? Unless the bushing part is porous ????
Old 12-10-2017, 07:11 PM   #6
pgerhardt
pgerhardt's Avatar
Picture 4 is indeed a part from the starter bendix, but I am guessing foxfire42 is correct on picture 5
Old 12-10-2017, 07:53 PM   #7
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
The bottom rt. Is the nut that holds the timing gear in place if it is about 2 in in dia
Jacksonlll is offline   Reply With Quote
Old 12-10-2017, 08:15 PM   #8
foxfire42
foxfire42's Avatar
I stand by my "guess" on the cam shaft nut.
Old 12-10-2017, 08:50 PM   #9
redmodelt
redmodelt's Avatar
Maybe they planed on the bushing being tight on the cross shaft and grease only getting between the bushing and carrier.
Old 12-10-2017, 08:54 PM   #10
pgerhardt
pgerhardt's Avatar
It is!
Old 12-10-2017, 09:05 PM   #11
davehc
davehc's Avatar
That grease cup is just like the ones on my hitmiss engines . After you fill the bottom screw in part with grease , you screw the top on and it will force the grease out a little at a time as you turn the cap in .
davehc is offline   Reply With Quote
Old 12-10-2017, 09:08 PM   #12
Clem Clement
Agree bottom right is a cam shaft nut.
Old 12-10-2017, 09:24 PM   #13
foxfire42
foxfire42's Avatar
Delete!
Old 12-10-2017, 09:30 PM   #14
foxfire42
foxfire42's Avatar
Thanks Clem.....I feel vindicated. For a minute I was thinking I was the nut. I sure love this Forum. Every day is like an advanced class in Model A. It may hold the timing gear on but it's called a cam nut.
Sorry JacksonIII I misread your response........When I tried to correct what I wrote it wouldn't let me.............darn computers!!!!! Delete is the best I could do.
Old 12-10-2017, 10:44 PM   #15
700rpm
700rpm's Avatar
I hope you didn't pay too much for that stuff.
Ray Horton, Portland, OR
700rpm is online now   Reply With Quote
Old 12-11-2017, 05:00 AM   #16
3.6rs
3.6rs's Avatar
As I sometimes do I put in a minimum bid in a "grab bag" of model A parts on E-Bay, and won! I got some good model A parts, and some stuff I could not identify. I thought I would put it out there to see if you know what they are. ..
I hope you didn't bid more then $1.00... including postage...
3.6rs is offline   Reply With Quote
Old 12-11-2017, 05:01 AM   #17
juke joint johnny
juke joint johnny's Avatar
I have one of those twist in grease caps on my water pumps,
Handy to give it a twist if the pump starts to drip.
and better than searching under the seat for the right grease gun
juke joint johnny is offline   Reply With Quote
Old 12-11-2017, 12:57 PM   #18
100IH
Grease cups known as Lunkenheimers: original manufacturer. Potentially feeding to a sintered bronze bushing (oilite) that was originally porous but bush has been replaced with copper which is caveman, perfect for an A.
100IH is offline   Reply With Quote
Old 12-11-2017, 10:50 PM   #19
pgerhardt
pgerhardt's Avatar
No. Minimum bid. 10 bucks, and there was some good stuff other than the items I could not identify.
Thread Tools
Display Modes
