12-08-2017, 12:06 AM | #1 |
Engine numbers to car years?
I have an engine number that is for April 1930. Could that have been used on a 1931 car, or is it too soon?
What is usually the time lag of an engine number to a car year? |
12-08-2017, 03:15 AM | #2 |
Re: Engine numbers to car years?
There should no more than a 3-4 month difference between engine manufacture and final car assembly.
I Love Anything That Turns Money Into Noise Last edited by Dollar Bill; 12-09-2017 at 04:39 PM. |
12-08-2017, 03:24 AM | #3 |
My April or May 1931 slant windshield non indented firewall Town Sedan has the original November 1930 engine.
12-08-2017, 07:30 AM | #4 |
Our 29 Sport Coupe has a firewall date of June 18, 1929 and the engine (matching number) has an approval date also of June 1929.
I think the only real answer is, “matching numbers”. If they match, end of story. From what I have read over the years. Engines could sit in storage after approval for days or sometimes months. Enjoy. |
12-08-2017, 08:39 AM | #5 |
Does the engine have it's "original" number or is it a "restamp"?
Pluck |
12-08-2017, 09:01 AM | #6 |
What would be interesting to know is the time engines were waiting to be shipped,assembling thousands a day its highly unlikely they stayed at the Rouge any longer than it took to load them in a rail car.Imagine in 1929 rail was still efficient,nowadays you get a three day window on freight cars being dropped at a siding.Ford had enough control to demand efficiency based on volume.Unit trains could have been made up and left the Rouge directly for the assembly plant,eliminating the need for the railroad taking cars to their yard and humping them to build a unit, shortening the time from the motor building to the assembly point. The use of rail for warehousing is common,load the engines into cars,the car becomes the warehouse.Store the cars in a marshaling yard for as long as you can.Wonder how many engines Ford put in a rail car... Last edited by Railcarmover; 12-08-2017 at 09:18 AM. |
12-09-2017, 12:13 AM | #7 | |
Pluck |
12-09-2017, 10:14 AM | #8 |
12-09-2017, 11:03 AM | #9 |
How do you find date info from engine number?
12-09-2017, 11:16 AM | #10 |
The Model A Ford Garage has a good article on this. Should give you all the needed information.
As far as a re stamp goes, look for grinding marks. You should be able to tell if there is a problem. Frame and engine should have the same VIN if engine is original to car. I have never owned a car that did not have matching numbers. Enjoy. |
12-09-2017, 12:12 PM | #11 |
WHN So my question to you is have you had the bodies off all of the cars you have owned? I have often wondered what "numbers match" really means.
12-09-2017, 12:38 PM | #12 | |
On Model A’s the engine number is put on frame at time of assembly. Therefore both should be the same to confirm, as much as you can, car to be original. Other makes have VIN’s on frame, engine, transmission, whatever. We have always checked our A’s, lifting body corner to check frame. Having only owned Sport Coupes so it has been a little easier. Door off, top off to replace, gas tank out to slosh, fenders off along with running boards to paint, not a problem. Enjoy. |
12-09-2017, 12:43 PM | #13 |
If the number pad has an as cast finish, chances are it's never been re stamped, if it's been ground smooth, chances are it has been re stamped.
12-09-2017, 01:11 PM | #14 |
WHN My question was do you lift the bodies to verify? So are you saying is the seller allows you to lift the body for inspection? I know that the number was also on the frame but cannot be seen until raising the body.
12-09-2017, 01:48 PM | #15 | |
28 and 29 Model A’s have manufacturing date on firewall above steering column. If engine number and manufacturing date don’t make some sense, or if engine number is different from title or DMV info I would pass on car. Lucky so far. I wouldn’t ask someone if they minded me taking car apart to check numbers. There are plenty of Model A’s out there. Everyone doesn’t feel the need for a numbers matching car. Enjoy. |
12-09-2017, 02:01 PM | #16 |
WHN Thanks for the response. Now I understand! Merry Christmas!
12-09-2017, 02:07 PM | #17 |
12-09-2017, 08:46 PM | #18 |
Re; 28 and 29 Model A’s have manufacturing date on firewall above steering column.
All the information I have come across says that is the date the gas tank was tested not when the car was built.
12-09-2017, 10:22 PM | #19 | |
I think the closer the car was assembled to Dearborn, the date on the gas tank and the true assembly date of the vehicle will be real close. BUT the further away the car was assembled to Dearborn, the date on the gas tank and the true assembly date of the vehicle will be further apart. See the following data: http://www.plucks329s.org/pdf/studie...te%20Study.pdf I would really like to update this if anyone has an ORIGINAL assembled vehicle with the needed information...please let me know. Pluck |
12-10-2017, 11:36 AM | #20 |
