04-15-2017, 02:50 PM | #1 |
re-wiring the 6 volt horn for 12 volt use
I'm using the 6 volt reducer for the horn on my coupe which is converted to 12 volt. Has anyone re-wired their horn for 12V and if so, what size and length of wire did you use and are you satisfied with the result ?
Thanks |
04-15-2017, 02:54 PM | #2 |
Re: re-wiring the 6 volt horn for 12 volt use
I've run 6v ahooga horns on 12v for years with no apparent damage.
No restorable Model A's were harmed in the building of this truck! |
04-15-2017, 03:28 PM | #3 |
Attached article might be of help.
Tom Endy |
04-15-2017, 03:36 PM | #4 |
Thanks Tom E. that is exactly what I'm looking for
Tom B. |
04-15-2017, 04:15 PM | #5 |
