Old 12-11-2017, 08:06 PM   #21
JSeery
JSeery's Avatar
Default Re: 34 Side Glass Install- HELP!
OK, hadn't seen that style of channel, but then there is a lot I haven't seen!! So you solved the issue with getting the glass in?
Old 12-11-2017, 09:46 PM   #22
Karl
Karl's Avatar
I hope so !
Karl is offline   Reply With Quote
Old 12-12-2017, 08:18 PM   #23
MAD 034
Please forgive me for not properly introducing myself first but United Pacific (the steel deuce 5W people) make nice window retaining channels for '34 Fords.
MAD 034 is offline   Reply With Quote
Old 12-12-2017, 08:40 PM   #24
JSeery
JSeery's Avatar
MAD, do you happen to have a link for that part? All I can find on their site is 32 5w parts.
Old 12-12-2017, 09:31 PM   #25
johnboy34
They are here, Classic car division.
http://www.uapac.com/antique/
http://www.uapac.com/antique/1934-fo...s-channel.html
Maybe they can be altered for 5 window and 4 door.
johnboy34 is offline   Reply With Quote
Old 12-13-2017, 03:10 AM   #26
Karl
Karl's Avatar
They look ok -What is the difference between Fordor and 3 Door Window channels -ie Easy to convert -Karl
Old 12-13-2017, 06:14 AM   #27
McCready
McCready's Avatar
Send a message via MSN to McCready
There's some measurements in the restorers book
McCready is offline   Reply With Quote
Old 12-13-2017, 03:03 PM   #28
FlatheadTed
FlatheadTed's Avatar
Karl The difference between 3window 4door
Is the glass is longer on the 3 window so the channel is longer most channels need trimming so it has less cut of the end at the rear about 2" longer .The ones I have checked from the roller gap forward all channels are the same ,not sure about Tudor but I think the same would apply .
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 12-17-2017, 11:07 PM   #29
Karl
Karl's Avatar
Finally Success
This is how I did it step by step
1. Remove rail and then remove regulator
2 Install glass and push right up Hold in pace with duct tape
3. Place regularator inside door with arms down
4. Install rail on regulator arms
5. Install regulator in door
6. Move rail up and down by winding regulator through full range Slide rail back or forward to insure regulator arms don't pop of rail ends ( A little silicone helps )
7. Fill channel with urethrane . Don't use glass setting tape as nothing can move with this and some movement is required
8. Wind the rail up and guide onto base of glass
9. Wind up fully
10.Clean excess ooze off
11. Leave for 24 hours
