10-14-2019, 12:10 PM | #1 |
Spark plug insert came out with the plug
I changed spark plugs on Edmunds aluminum heads. I had a steel spark plug insert come out with the plug. Am I right this was put in to repair a stripped plug hole? I tried getting the insert off the old plug with solvent and heat but can't without buggering up the threads. Where can I get another insert? Then I could put a new one back in with red Loctite. Any help appreciated
10-14-2019, 12:32 PM | #2 |
Re: Spark plug insert came out with the plug
I think NAPA sell them individually, if not a small engine repair should have them. I've fixed a couple of lawn mowers with them.
10-14-2019, 01:24 PM | #3 |
There are different styles--- take it with you to match it
10-14-2019, 06:17 PM | #4 |
I've used the KD brand thread inserts. And, yes, the ones I've experienced, all come out with the plug. In the distant past, I've been able to get KD inserts.
10-14-2019, 06:22 PM | #5 |
Make sure you take a good spark plug with you to "test fit" the matching threads.
10-14-2019, 06:52 PM | #6 |
10-15-2019, 07:23 AM | #7 |
Thank you all for the good info
10-15-2019, 12:28 PM | #8 |
If I'm not mistaken, they don't recommend any type of Locktite or other adhesives etc. It might prevent the plug from making good electrical contact in the head.
10-16-2019, 04:52 AM | #9 |
Good to know Woodie I'll look into that.
