Old 09-22-2019, 07:03 AM   #1
cederholm
cederholm's Avatar
Default 8BA oil direction
Getting ready to fire up my freshly rebuilt 1953 8BA for the first time and I want to make sure I have everything correct. I've never run this motor before.
The oil system has been converted to high-flow. Am I correct that the oil is LEAVNG the engine from the outer most fitting (away from the block)? The fitting that shared the port where I have the oil pressure sender? See photo.
Thanks,
Carl
cederholm is offline   Reply With Quote
Old 09-22-2019, 08:14 AM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: 8BA oil direction
Sounds good to me.
You should also check flow direction on filter adapter.
Old 09-22-2019, 08:23 AM   #3
cederholm
cederholm's Avatar
Awesome! The filter adapter is well marked - thank you!
Old 09-23-2019, 01:23 PM   #4
Zeke3
Zeke3's Avatar
I don't think it is a good idea to use worm hose clamps on a pressurized oil line. You are one clamp failure away from a toasted engine or worse.
Zeke3 is offline   Reply With Quote
Old 09-23-2019, 01:29 PM   #5
V8 Bob
V8 Bob's Avatar
Agree^^^ If you want to use plain black hose, use high quality socketless (push-lock) #8 hose and fittings, like those from Aeroquip, that I use.)
Old 09-23-2019, 01:50 PM   #6
cederholm
cederholm's Avatar
thanks for the warning guys.
Old 09-23-2019, 02:14 PM   #7
51 MERC-CT
51 MERC-CT's Avatar
Or if the filter is mounted on the engine it could be hard plumbed.
