10-07-2017, 01:40 PM | #1 |
Truck stall when coming to a stop
I know this has been covered a lot but it has me baffled. Truck has been doing fine no problem nice idle and never died when braking to a stop.
Lately it was doing it once in awhile now it does it every time! Even with clutch in braking to a stop sign and she just drops off. Idle mixture I have adjusted several time and no change. So why now? Is the float sticking? Made no changes internally to the Zenith Thanks |
10-07-2017, 01:53 PM | #2 | |
Re: Truck stall when coming to a stop
10-07-2017, 03:28 PM | #3 |
I had a bad ignition switch and every time i hit the brake it shut off
10-07-2017, 04:24 PM | #4 |
Go through and clean out the carb. After that clean out the sediment bowl and when doing so check for water in the bottom of the bowl. None of the gaskets have deteriorated have they? Dave
10-07-2017, 04:24 PM | #5 |
Tighten your carb connection to the manifold. If not there, somewhere you have a leak in the intake system.
10-07-2017, 04:52 PM | #6 |
10-10-2017, 07:14 AM | #7 |
Tore carb down soaked cleaned passages and jets. light junk in mid well and idle passages. Works fine now. Thanks for your suggestions.
10-10-2017, 07:55 AM | #8 |
This is why I love the Ford Barn Thanks Ryan!
10-11-2017, 07:20 AM | #9 |
It's quite common for Zeniths to stall, on a QUICK, HARD stop! That's why Henry redesigned the Float Chamber!
Bill W.
Thread Tools | |
Display Modes | |
