12-16-2016, 02:53 AM | #1 |
piston clearance
Can anyone advise the piston clearance when using steel pistons? 39 Mercury. Thank you.
12-16-2016, 04:52 AM | #2 |
Re: piston clearance
The clearance requirement with stock stroke is .060 with new rods and .045 with used rods.
12-16-2016, 05:59 AM | #3 |
Piston to head? or piston to bore?
12-16-2016, 08:36 AM | #4 |
Good question!!
12-16-2016, 09:32 AM | #5 |
In the Ford book the clearance is listed in lbs pull for a feeler gauge, alum piston the same except in plain bores--you didn't say what bores(tin sleeve, or plain)
steel sleeve, steel piston, .003 feeler gauge, 6-10 lbs pull plain bore, steel piston , .0025 feeler gauge more for worn piston, and worn bore different makes of pistons use different clearance, the listed specs are for Ford parts |
12-16-2016, 11:23 AM | #6 |
12-16-2016, 12:37 PM | #7 |
Sorry, I was not more specific in my wording....thank you Kurt, you supplied exactly what I was after.
01-25-2018, 01:49 PM | #8 |
Piston at tdc and right side up?
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
01-25-2018, 08:53 PM | #9 |
