Old 10-07-2019, 07:55 AM   #1
chrs1961815
chrs1961815's Avatar
Default Replating Gear Shift Lever
I want to get two gesr shift levers replated but they are kind of rusty and I want to clean it. I don't think blasting is the best option.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 10-07-2019, 08:08 AM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Replating Gear Shift Lever
Use a chemical rust remover such as Evapo-rust or Rust911 first. Then either remove the remaining plating electronically or let the plater do it. It is very easy to ruin a gear shift lever if it has much pitting, or needs much buffing. It is hard for them to keep the stick from becoming wavy.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 10-09-2019, 08:13 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
I used a belt sander on my 2 levers before getting them nickel plated.
As Brent said, it's real easy to make them look wavy, so use lots of care.
Old 10-09-2019, 10:45 PM   #4
updraught
updraught's Avatar
The bell shaped cover at the bottom has to fit the stick. If you grind too much off there it will flop around. A good platter can build up the pits with copper plate and grind it down.
updraught is offline   Reply With Quote
Old 10-10-2019, 05:55 AM   #5
rrich1
rrich1's Avatar
wire wheel on a drill press or bench grinder does wonders and doesnt take off material like a sander. puts a nice finish on as well. i do this with my hand planes when i restore them.
rrich1 is offline   Reply With Quote
