Old 01-20-2020, 12:06 PM   #1
whirnot
whirnot's Avatar
Default Cab mounting blocks
Restoring a 30 CCPU, and I plan on replacing all the mounting blocks. Some of the ones I removed have places where they are cut down, possibly where the frame hits. But there are a lot of things not right.
Can anyone tell me if there are supposed to be "cutouts"
In the blocks? There is one that has a curved relief to follow the cab channel, that one appears obvious.
Also, after removing the top, I thought it would be a good idea to glue bamboo toothpicks into all the nail holes to make a new tight fit. Any reason not to go this way? The wood is in pretty decent shape.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
Smith Motor Compressor
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 01-20-2020, 12:28 PM   #2
Steve Plucker
Default Re: Cab mounting blocks
Bill,
Most of the body blocks that I have seen have always had those "cutouts" that you speak of. Those areas are where the anti-squeek rubber pads are nailed to which come in contact with the frame.
Are you restoring the 28-mid 30 cab or the later 30-31 cab?
Pluck
Old 01-20-2020, 03:28 PM   #3
whirnot
whirnot's Avatar
Ok, that makes sense, although there were no pads.
(No surprise)
Thanks Pluck,
Am restoring a Dec. 30
Bill Worden
1929 Roadster
1951 Ford F1
Old 01-20-2020, 04:28 PM   #4
Brentwood Bob
Les andrew's red manual covers that. Sounds like you may have recovered the original body bolts if the blocks were intact.
Brentwood Bob is offline   Reply With Quote
