Old 01-21-2020, 12:19 PM   #1
Alaska Jim
Alaska Jim's Avatar
Default y-block aluminum manifold clamps
I was just looking at Mummerts web site trying to find a price on his aluminum intake clamps, but could not find them on his price sheet. Before I call just to get a price, I was wondering if anyone here knows what the price for them is, and has anyone used them.- Thanks ----Jim
Alaska Jim is offline   Reply With Quote
Old 01-27-2020, 10:46 AM   #2
KULTULZ
KULTULZ's Avatar
Question Re: y-block aluminum manifold clamps
Did you ever get an answer Jim? There is a similar thread on THE OTHER FORUM ...
I Occasionally Enjoy Running My Fingers Through My Wife's Hair ...
One To Show My Deep Affection For Her, and ...
To Casually Remind Her We Are Out of Napkins ...
And Then It Hit The Fan ...
KULTULZ is offline   Reply With Quote
Old 01-27-2020, 05:06 PM   #3
Alaska Jim
Alaska Jim's Avatar
Default Re: y-block aluminum manifold clamps
Kultulz, yes and no. I started the thread on the y block forever forum. never found a price for the Mummert ones, found some Blue Thunder ones on ebay for $46.00. I bought them, and will see if I like them for my current avatar. I am changing the Offy 3x2 intake for an Edelbrock 3x2 #573, as it performes much better. I am also changing the carbs , making the center carb an ECG 6 with the larger throttle blades. if I do not like the clamps on the Edelbrock intake, I can use them on something else.
Old 01-28-2020, 03:04 AM   #4
KULTULZ
KULTULZ's Avatar
Post Re: y-block aluminum manifold clamps
Then you saw the illustration of the MUMMERT retainers I posted. It listed different ones for the OFFY and EDEL
Let us know if you go that way.
Old 01-28-2020, 04:12 PM   #5
Alaska Jim
Alaska Jim's Avatar
Kultulz, The current offy intake on my avatar is using stock steel clamps. I wanted to get away from them on the Edelbrock manifold, to keep from ending up with gouge marks on the aluminum manifold. the used Edelbrock had quite a few gouges in it when I bought it. my brother the machinist dressed it up so it does not look bad. hoping to avoid gouges by using solid aluminum clamps. we will see if the off-set on the blue thunder clamps will be a problem. one thing Ted Eaton mentioned on the other site , is that there are different size stock clamps depending on year and application. this is something I did not know. not many y-blocks, or flatheads, have survived the scrap drives of the '90's up here. ( or any thing else that was more than 10 years old at the time, and most of the old cars went to the crusher. very sad ).
Old 01-28-2020, 07:56 PM   #6
KULTULZ
KULTULZ's Avatar
Thumbs up Re: y-block aluminum manifold clamps
That is what would concern me is the gouge markings (and it hurts re-sale value). I could not find in period cataloging if E-CODE intakes used steel or alum clamps. I need an earlier period catalog.
Old 01-29-2020, 02:42 AM   #7
KULTULZ
KULTULZ's Avatar
From THE OTHER FORUM-
SOURCE - http://forums.y-blocksforever.com/Topic150057.aspx
Old 01-31-2020, 10:17 AM   #8
KULTULZ
KULTULZ's Avatar
Seems OEM were all steel -
