Old 12-15-2019, 10:13 AM   #1
xelhan
Default Power Steering for AA Truck
Hi,
I would like to convert my 1930 Ford AA Truck with Power Steering.
I have installed a pump already and need a suitable Power Steering Box. I’m looking for something that will fit nicely. I have no problem to fabricate brackets and do machine work if necessary.
Any suggestion or input would be much appreciated.
Chris
xelhan is offline   Reply With Quote
Old 12-15-2019, 01:46 PM   #2
supereal
supereal's Avatar
Default Re: Power Steering for AA Truck
I suggest you look into adapting a rack and pinion setup. Easier and less expensive than adapting different steering gear.
supereal is offline   Reply With Quote
Old 12-15-2019, 03:44 PM   #3
xelhan
I would like to keep the original type of steering and it's probably a bit heavy for RP
Old 12-15-2019, 03:48 PM   #4
Merc Cruzer
Merc Cruzer's Avatar
After reading V8COOPMAN's post , my suggestion of early 50's Lincoln PS, would not have worked.
Merc Cruzer is offline   Reply With Quote
Old 12-15-2019, 05:57 PM   #5
51504bat
51504bat's Avatar
A power steering box from a Toyota 4x4 p/u (I believe mid '80's) is a push pull box but it might be a little wimpy for a big truck like an AA.
Old 12-15-2019, 06:48 PM   #6
V8COOPMAN
V8COOPMAN's Avatar
If I'm not wrong, I believe Model AA big trucks still had the side steering, with the drag link controlling the LEFT side spindle...not cross steering. This needs to be kept in mind when offering suggestions as xelhan wants to keep the original configuration, similar to the drawing below. Many thanks to Mac VP for the use of your drawings.
NICE truck!! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 12-15-2019, 07:03 PM   #7
Charlie Stephens
I wonder if the F100 steering that Randy Gross converts might be the answer, [email protected], 714-292-8660 Not power but might be enough. You might ask him if he has ever done an AA.
Also note that you are posting this thread in the 1932-53 section, not the Model A section.
You might also ask your question on HAMB, https://www.jalopyjournal.com/forum/...ssage-board.5/
Charlie Stephens
Old 12-15-2019, 08:01 PM   #8
Bob C
The AA uses the same box as the A.
Bob
Old 12-15-2019, 11:45 PM   #9
FlatheadTed
FlatheadTed's Avatar
What about using a Mustang ram onto the tie rod ,
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 12-16-2019, 04:15 AM   #10
Mart
Mart's Avatar
The modern trend is to adapt an electric power steering assist into the column. UK rodder Gus put one on his A coupe. It's hard to hide the unit but it can be done neatly.
I also remember an article in street rodder where they adapted 50s Ford power steering to a push pull setup. It took a lot of work with hoses and everything but it can be done.
Mart.
Old 12-16-2019, 04:29 AM   #11
Tinker
Tinker's Avatar
Once you go hydrophilic look at rock clawer stuff.
Vega boxes were great and standard for stuff still mech.
Old 12-16-2019, 07:51 AM   #12
Ol' Ron
Ol' Ron's Avatar
A simple power assist piston might work. This was one of the original Ford PS systems abd just attached to the normal steering. can't be simpler than that.
Old 12-16-2019, 08:34 AM   #13
jimTN
Or, use a box from a 48-53 F6. Just try one, they steer very easy and have the correct style to mate to your AA
Old 12-16-2019, 12:09 PM   #14
flatheadmurre
flatheadmurre's Avatar
If you don´t mind turning the steeringwheel a few more turns the F6 box would be an easy solution.
Should be 1 or 2 heavy trucks out in my yard if you need one...
Old 12-16-2019, 02:52 PM   #15
Pete
Pete's Avatar
A system that uses a linear control valve is the simplest to adapt.
The control valve is in the cylinder so no adaption to the steering box.
Some early Nash's had them. Many Fords had them.
Here is a Nash adapted to a race car.
It pushes on the pitman arm. The back end anchors to the frame.
Old 12-16-2019, 02:54 PM   #16
cas3
thats what i was going to suggest too. common on tractors and industrial stuff
Old 12-16-2019, 05:12 PM   #17
Lawrie
Lawrie's Avatar
Vickers made them , they were on lots of small trucks and tractors here.
all you need is the pump and the unit to the drag link or replaces the drag link.
Lawrie
Old 12-16-2019, 06:11 PM   #18
Bob C
Looks similar to what Ford had.
Bob
Old 12-16-2019, 07:19 PM   #19
V8COOPMAN
V8COOPMAN's Avatar
Bob
Man, that ought to look nice in that left wheelwell with those big, open fenders. DD
T5 W/TORQUE TUBE
Old 12-16-2019, 09:00 PM   #20
Pete
Pete's Avatar
I prefer the Nash. It only has 2 hoses and when installed it is behind the running board apron on a model A, out of sight.
