06-22-2015, 11:22 AM | #1 |
zenith Carburetor whistle
My Zenith carb on my 4 cylinder model B engine has begun to whistle. The whistle seems to be coming from the throttle port because I cam control the severity of the whistle by placing my fingers around this port.
Are the gaskets and o rings that might solve this problem included in the rebuild kit for the zenith carb. Any help will be greatly appreciated. |
06-22-2015, 12:59 PM | #2 |
Re: zenith Carburetor whistle
I know that they will whistle if you forget to put the venturi back in!
They sort of run but not as bad as you would think! Do not ask how I know this!! |
06-22-2015, 01:00 PM | #3 |
Every time I have heard a whistle from the direction of the carburetor, it has been due to a leak between the carburetor and intake manifold (gasket, irregular surfaces, broken intake, etc.). Good luck with it.
Peyton |
06-22-2015, 01:19 PM | #4 |
Great info guys. I recently loosened the carb to the intake manifold to help my put a new carb to fuel pump fuel line. I will change the intake gasket..Do I need to seal with permetex gasket sealer?
06-22-2015, 01:27 PM | #5 |
i dont use permatex
but i always use the copper style base gasket... they are thicker and can be reused easy that being said if your current gasket is in bad shape use permatex |
06-22-2015, 01:43 PM | #6 |
06-22-2015, 01:43 PM | #7 |
Frank,
Do you have an Otwell manifold heater installed? |
06-22-2015, 01:51 PM | #8 |
wow...Not that I know of. I purchased the 1933 model b last July..
Most of it is original except I know that it once had a heater for inside the car. The heater is no longer there but my exhaust manifold has fins and there was a hose connection from my block. But you are not referring to that type of heater, right. |
06-22-2015, 02:19 PM | #9 |
i had a carb whistle once because the throttle shaft was loose and that also caused the idle to stick high at times.
06-22-2015, 02:26 PM | #10 | |
Is there a straight forward way to tighten the shaft or do I have to take the carb apart and add new bushings. Last edited by FrankWest; 06-22-2015 at 02:40 PM. |
06-22-2015, 02:32 PM | #11 |
i use the oversize shaft FIRST... real easy to put in with a drill bit... to go the oversize bushing route (which uses the original size shafts) it must be drilled larger than the oversize shaft size so your better off doing the bushings once the oversize wears out
the only other thing you can run into if it alrady has an oversize shaft installed then u need to go the bushing way does that make sense |
06-22-2015, 02:33 PM | #12 |
You'd have to remove the plate and shaft, then drill the housing for the new bushings.
Mitch is a faster typer, and I like his idea of a larger shaft. |
06-22-2015, 02:44 PM | #13 |
From your comments I take it this repair goes beyond the simple carb rebuilding kit.
06-22-2015, 02:57 PM | #14 |
Frank,
IF it's "WHISTLING DIXIE", jist leave it ALONE!! Bill W.
06-22-2015, 03:05 PM | #15 |
A quick Farmer Fix is to take off the carb and unscrew the small fasteners and then remove the throttle round plate. Pull out the shaft and put a couple of turns of gas resistant Teflon pipe tape around on the shaft area where it goes through the carb body. Put the shaft back in by twisting it back and forth and make sure it is positioned correctly. Then put back in the plate with it's fasteners. Re-install the carb on the car and you should be good to go and now whistle free....
06-22-2015, 03:17 PM | #16 |
frank you can do it with the carb fully assembled
remove the throttle plate and old shaft then shove a depends inside to prevent the shavings from going in if i had a 5 year old still i would let her do it lol |
06-22-2015, 03:19 PM | #17 |
Funny!!!!!
06-22-2015, 03:21 PM | #18 | |
06-22-2015, 03:23 PM | #19 | |
Bud says......This is so easy even a 5 year old kid could do it... Costello answers...Yeah, but where are we going to find a 5 year old kid? |
06-22-2015, 03:33 PM | #20 | |
06-22-2015, 03:55 PM | #21 |
06-22-2015, 04:37 PM | #22 |
Priceless!
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio |
06-22-2015, 06:12 PM | #23 | |
06-22-2015, 06:15 PM | #24 |
Who sells the over sized throttle shafts for the Model B Zenith?
Thanks Last edited by Benson; 06-22-2015 at 06:21 PM. |
06-22-2015, 06:33 PM | #25 |
I was able to get the throttle rod out on a spare carb I have.
I am amazed at the ingenuity that went into these wonderful engines created almost 90 years ago. Amazing. I stand in awe! |
06-22-2015, 06:37 PM | #26 |
its always good to put in new screws |
06-22-2015, 06:40 PM | #27 |
06-22-2015, 07:50 PM | #28 |
Thanks Vince,
I had never seen repro B shafts in STD or oversized either. From the discussion about using oversized shafts; I wondered if someone was making B shafts that I did not know about. Hence the question. |
06-23-2015, 03:01 PM | #29 | |
Thanks. Peyton....You're a Genius! Last edited by FrankWest; 06-23-2015 at 03:27 PM. |
06-23-2015, 06:54 PM | #30 |
Had one whistle do to the butterfly once, air passing by caused it, someone had tried to modify it and I replaced the butterfly...
06-24-2015, 05:25 AM | #31 |
Amazing! I had no idea that such a strong vacuum existed on these engines...It is amazing the engineering effort that took place over 90 years ago.
06-24-2015, 06:52 AM | #32 | |
The first time my Son, Gregg, (RIP), saw the head off a Model A, he was AMAZED at the huge bore & stroke---------"That would make a great COMPRESSOR"!!---------"Yep, they use them for that also"--Chief heard of a Model A compressor, that by reversing some of the plumbing, it was converted for an emergency VACUUM PUMP to power a DAIRYS' milking machines, during a power failure. Bill W.
06-24-2015, 02:15 PM | #33 |
Another farmer fix that I use on the B throttle shafts is to remove the shaft, clean it well, and paint some POR-15 epoxy coating onto the portion that runs in the bore. Reposition it several times during the first few hours of drying so that it will dry evenly. As it sets up I will leave it with the worn side down. It will dry to a very hard finish with about 5-6 thousandths additional diameter. Check the fit and sand it a bit if necessary. Grease it and install. Works for me.
06-24-2015, 08:18 PM | #34 | |
It blows my mind... I guess when you think of it... Those old steam locomotives had a technology that surpasses our mechanical technology today. Valves, fittings and controls had to be almost perfect to harness the brute strength of the steam. |
06-24-2015, 08:21 PM | #35 | |
I will record it because I may need it someday. |
