06-03-2019, 07:03 PM | #1 |
Copper Clad Head Gasket on a Brumfield 5.9 Head
Can some please tell me, For the life of me I can't remember. Im getting old and just can't remember. Which WAY DOES THE Fel Pro COPPER CLAP HEAD GASKET GO ONTO THE block:::
Do Seems go up or Do the Seems go down onto the engine block Thank You in advance , Hugh |
06-03-2019, 07:49 PM | #2 |
Re: Copper Clad Head Gasket on a Brumfield 5.9 Head
Per the consensus, it seems seams go up.
06-04-2019, 05:10 AM | #3 |
Brumfield 5.9 Head Copper clad head gasket , did you say the "gasket seams" go up on the block?
Hugh |
06-04-2019, 05:58 AM | #4 | |
Mr. Smith, most people suggest that the seam (-which likely/often imprints the adjoin metal when torqued) is placed towards the cylinder head as that is easier to resurface than the block's deck surface. |
06-04-2019, 06:26 AM | #5 |
Brent,
What? did you say, Im cornfused? "most people suggest that the seam (-which likely/often imprints the adjoin metal when torqued) is placed towards the cylinder head as that is easier to resurface than the block's deck surface" So that would Be placing the Gasket "Up" on the block Is that correct? Thanks, Hugh . |
06-04-2019, 07:14 AM | #6 |
06-04-2019, 10:07 AM | #7 |
See Vince Falter's Fordgarage.com for Brumfield info.
