09-13-2013, 12:14 PM | #1 |
RTS 4 sp trans info needed
Which Ford mid 80's RTS 4sp transmission is used in the Model A conversion? 2wd - long tail shaft or 4wd - short tail shaft?
09-13-2013, 12:38 PM | #2 |
Re: RTS 4 sp trans info needed
PM sent
09-13-2013, 04:13 PM | #3 |
Do a search on F150 4-spd and you'll find all the information you need.
AL in NY |
09-14-2013, 11:46 AM | #4 |
I have an 85 f-150 trans in my 29 tudor, it looks like they made a new part where the tail shaft bolts on the trans. It is a piece of aluminum about 1" thick and the u-joint cover (back half) bolts to the aluminum part. The driveshaft and torque tube have been shortened about 1.5" .
It is a great set-up. I did the change so my wife could drive the car. I have a Mitchell O/D in my 28 ccpu , but I drive the truck. I would say go for it to anyone wanting to make the change. |
09-14-2013, 07:51 PM | #5 |
'84 - '87 will work from 2wd or 4wd. I have done one of each. I think the codes to look for are; AD, AE, AJ, BJ, BP, BU, BV, BZ, or CS but check ratio before purchaseing. Turn input shaft 10 revolutions and look for 12.6 rev.s on the output shaft. Ron W
09-14-2013, 08:24 PM | #6 |
09-15-2013, 10:33 AM | #7 |
Jack 34pu, Ken Parker is a good guy to talk to if you would like to buy a kit or if you have questions. He helped me a lot! AL in NY also knows a lot about them. Ken, good to hear from you. When I cut the splines on the short output shaft, I put the hole between the splines and it almost disappears. Doesn't hurt anything. I just sent you an e-mail with a picture. Ron W
09-15-2013, 11:07 AM | #8 |
One of the better threads on this subject here, it also has some good links embedded in it.
http://fordbarn.com/forum/showthread...highlight=f150
It's not what people think they know that will hurt them, it is what they think they know that aint so! -Mark Twain. It is the very things that we think we know, that keep us from learning what we should know.- Unknown |
