08-17-2018, 11:19 AM | #1 |
Do A's turn sharper in one direction?
If not, someone explain this to me. With the wheels pointing straight ahead, and the drag link disconnected, the steering arm (the one with the ball on the front axle), travels much farther forward from a given point than it does backward.
I can't seem to figure out the geometry of this thing. |
08-17-2018, 11:36 AM | #2 |
Re: Do A's turn sharper in one direction?
Steering stops equal?
08-17-2018, 11:55 AM | #3 |
The steering arm should be directly above and parallel to the axle. If not, the arm is bent and will steer as yours is. Heat and straighten and it will be fine.
08-17-2018, 10:26 PM | #4 |
Which arm is the "steering" arm? The Spindle arm?
Maybe it has to do with the Ackermann angles? https://en.wikipedia.org/wiki/Ackerm...ering_geometry .
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 Last edited by 1955cj5; 08-17-2018 at 10:59 PM. |
08-17-2018, 10:32 PM | #5 | |
Bill W.
08-18-2018, 11:08 AM | #6 |
