Old 06-19-2019, 05:50 AM   #21
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Default Re: Mystery Missfire
I come back to an intake leak. A cracked intake manifold can be hard to find. Good luck and let us know what you find.
Jacksonlll is offline   Reply With Quote
Old 06-19-2019, 01:32 PM   #22
john charlton
john charlton's Avatar
1001H prompted a train of thought and I removed no4 plug and started the engine and let it idle on 3 cylinders . Took a compression with the running engine and got a steady 40 PSI VOILA !!! Problem revealed my guess that tight valve clearance on the inlet valve . Checked the PSI on cranking and got 75 PSI . The earlier 65 PSI I got I forgot to open the throttle fully . So here is hoping that the engine has adjustable lifters I have never had the cover off but knowing my luck I guess it is a head off job . I will keep you all informed ,stay tuned !!!
John in heavy rain Suffolk County England/
john charlton is offline   Reply With Quote
Old 06-19-2019, 03:00 PM   #23
Ernie Vitucci
Good Luck, John...Ernie in Arizona
Ernie Vitucci is offline   Reply With Quote
Old 06-19-2019, 11:40 PM   #24
Tom Wesenberg
Tom Wesenberg's Avatar
If you have a sticky valve, then I'd add a can of Sea Foam to the gas, and another can to the oil.
In less than 5 miles a can of Sea Foam in the oil made my clicking Olds engine sound like new. This was back in the 80's on a Cutlass with a sticking hydraulic lifter.
Old 06-20-2019, 02:31 PM   #25
100IH
The needle bouncing steadily leans toward tight lash. Erratic bounce, sticking guide, weak or broken spring. Sloppy stem clearance and washed out cam lobe might be a steady but low reading. Compression test-wet&dry, vacuum test readings, cylinder leakage test and lastly this vacuum gauge sans check valve if needed is about as much help as a fella can get. Good luck. One thing we do know, valves won't stick closed over night. They can bounce, leak, wobble and dance or stay open. Then there are rings but that ought to be consistently low, not intermittant. Sorta like herding cats.
100IH is offline   Reply With Quote
Old 06-21-2019, 12:49 PM   #26
john charlton
Problem revealed no clearance on the exhaust valve not the inlet which I suspected . The inlet valve spring I can rotate by hand so I do have a clearance on that . I really dont want to pull the head just to fix one valve . Right now my 80 yr old brain is thinking that if I could compress the spring I could get a fine flat file and dress the valve foot to suit ( dont shudder ) I would of course use rags and powerful fridge magnet to catch any swarf . Has this been done before ??? Just thinking thinking thinking . DRAT no adjustable lifters
John in partly cloudy high pressure on the way Suffolk County England .
Old 06-22-2019, 01:08 PM   #27
100IH
This is a model A. There isn't anything that hasen't been done. Obviously it did not have adjustable lifters. Think I might try the same. File might not touch it due to hardness, got nothing to loose XX.
Old 06-22-2019, 01:29 PM   #28
nick c
John, I've done this, take a small rag like a piece of an athletic sock or towel, soak in motor oil, rap around lifter base, it will catch and hold the filings. Buy a new file it will cut with no problem.
carry on nick c
nick c is offline   Reply With Quote
