Old 07-04-2020, 03:25 PM   #1
AllenV
AllenV's Avatar
Default Can you ID this mystery part on my Y-BlocK?
All,
On my 55 F-100 project https://www.fordbarn.com/forum/showthread.php?t=273280
I have spotted an unidentified bracket with a nylon roller on a post. It is attached at the left rear, see photos, marked with a red arrow. This motor is a 292 transplant mated to a T98 4-speed. Based solely on the oil pan and dip stick (photos) it seems it came from a non-truck.
The block casting is. EDB 6015E above the oil filter
The head casting is ECG-T
Can anyone tell me what this nylon roller part is? Is has no function on my truck.
Allen
Allen
'55 F100 with slightly newer 292 Y-block
find the detailed project story at
https://www.ford-trucks.com/forums/1...o-project.html
AllenV is offline   Reply With Quote
Old 07-04-2020, 03:53 PM   #2
34pickup
34pickup's Avatar
Default Re: Can you ID this mystery part on my Y-BlocK?
Looks like its for a clutch Zbar or crosshaft mount for a standard shift.
Matt 24:36-41
34pickup is offline   Reply With Quote
Old 07-04-2020, 04:12 PM   #3
AllenV
AllenV's Avatar
Thumbs up Re: Can you ID this mystery part on my Y-BlocK?
Now that I know what to look to for I do find that sort of thing on the web. I think I'll just remove it and set it aside.
Thank You
Allen
Old 07-04-2020, 07:14 PM   #4
dmsfrr
dmsfrr's Avatar
Allen
Yes, the engine / oil pan came from a 'full sized' car. (photo 1)
Trucks and '55/'57 Birds use a rear sump oil pan. (photo 2) with the dipstick located on the side of the block, not in front. (photo 3 & 4)
Assuming the truck has clutch linkage, but it's set up differently?
dmsfrr is offline   Reply With Quote
Old 07-04-2020, 11:15 PM   #5
AllenV
AllenV's Avatar
Correct, the truck has an original clutch linkage for the F-100 with the 4-speed T98 transmission. A lever on the brake/clutch pedal support rod actuates the clutch from the rear. Perhaps there is more room underneath the cab in trucks vs sedans. The “z-bar “ is not used.
Allen
Old 07-04-2020, 11:47 PM   #6
Daves55Sedan
Daves55Sedan's Avatar
I noticed you have a car engine oil-pan on it. aren't you scared that when you hit a bump in the road, that the front straight axle won't pop up and crush the bottom of that oil-pan? There is a reason why they made a different oil-pan for the trucks.
Daves55Sedan is offline   Reply With Quote
Old 07-05-2020, 08:16 AM   #7
AllenV
AllenV's Avatar
Here is an image of an F100 clutch. The clutch pedal arm rotates that U-shaped shaft to pull on the lever attached to the clutch throwout bearing.
Allen
Old 07-05-2020, 08:18 AM   #8
AllenV
AllenV's Avatar
Quite a few trucks have this "feature". None, that I am aware of, have experienced catastrophic oil-pan contact. Most annoying is that the oil drain is right above the axle.
Allen
Old 07-05-2020, 09:00 AM   #9
darrell
ive seen 55 trucks with the front sump pan and people said they never came this way.said the pan wouldnt clear the crossmember in front of it.
darrell is offline   Reply With Quote
