Old 06-21-2020, 10:37 AM   #1
CA Victoria
CA Victoria's Avatar
Default 1935 Ford Temp Gauge
I want to run a 2nd temp gauge.
Did the 35 only have a provision for a temp probe in the drivers side water
pump?
Are the pumps interchangeable where I could run a drivers side pump on the passenger head?
Tim
Downtown, Ca
CA Victoria is offline   Reply With Quote
Old 06-21-2020, 11:51 AM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: 1935 Ford Temp Gauge
replacement pumps had a plug so they could be used on either side
Old 06-22-2020, 06:28 AM   #3
Terry,OH
Terry,OH's Avatar
I am not aware of a RH, OEM or aftermarket pump with the temperature probe fitting. The LH pump can be used on the right but the fitting winds up under the generator, I am not sure if the temperature probe can be installed in this location.
Old 06-22-2020, 07:27 AM   #4
deuce lover
deuce lover's Avatar
It actually gets very close to the spark plug wire tube.If using the original the line might not be long enough but then the gauge would have to be in some sort of housing.
deuce lover is offline   Reply With Quote
