Old 01-18-2013, 03:29 PM   #1
hankirk
Default lubricating throwout bearing '29 A
I am getting conflicting info on lubricating the throwout bearing on my early 29 A. Does the grease fitting on the slide shaft lubricate the bearing or just the shaft? The Model A Mechanic Handbook seems to contradict itself, in one paragraph it says it does and in another it says it does not. Is there a need to lubricate the bearing as well as the shaft and if so, how is it done?
hankirk is offline   Reply With Quote
Old 01-18-2013, 05:45 PM   #2
lindy williams
Default Re: lubricating throwout bearing '29 A
Model A's originally used greasable throw out bearings, however Ford started using sealed throwout bearings in 1935. To my knowledge, all modern replacement throwout bearings are sealed and cannot be greased.
lindy williams is offline   Reply With Quote
Old 01-18-2013, 06:26 PM   #3
Gary WA
Gary WA's Avatar
Remove floor boards and then remove transmission cover grease fitting right there! hit it with some grease.
www.whidbeymodelaclub.com
Old 01-18-2013, 06:48 PM   #4
miss victoria
all new ones are sealed national 2065
miss victoria is offline   Reply With Quote
Old 01-18-2013, 07:56 PM   #5
Larry Seemann
To answer your question: Assuming you have an original or otherwise lubeable bearing, greasing that fitting on the sleeve also greases the bearing. It is a bit of elegant automotive engineering - as the sleeve slides back and forth the grease that is in the sleeve is forced into the bearing. There are holes in the part of the sleeve that the bearing is pressed onto to allow the grease to get to the bearing and the shape and clearance on the sleeve is such that the grease just goes where it's supposed to. Be careful to not over grease it - 3 pumps per year should be enough - as it's very close to the clutch and you don't want any excess grease that may wind up on the flywheel.
Larry Seemann
Larry Seemann is offline   Reply With Quote
Old 01-18-2013, 08:13 PM   #6
miss victoria
hard to believe there are any orginial bearings still in service last made in the early 30s
Old 01-18-2013, 10:06 PM   #7
J Franklin
J Franklin's Avatar
I was surprised to find the greasable bearing in my '34 truck. It was in good shape so was reused.
Old 01-18-2013, 11:23 PM   #8
CarlG
CarlG's Avatar
Not TO bearing, but I was surprised to find original rear wheel bearings in my truck. They were in better shape than the repros I bought to replace them with, so I re-used the original Ford script bearings.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 01-19-2013, 06:48 PM   #9
Allanw
Allanw's Avatar
Our '29 Tudor still has a greasable TO bearing. :-)
Allan
'29 Tudor, Canadian RHD
Whangarei, NZ
"Duct Tape can't fix stupid, but it can MUFFLE the sound"
Allanw is offline   Reply With Quote
Old 01-19-2013, 07:14 PM   #10
Tom Wesenberg
Tom Wesenberg's Avatar
I'm still using the original throwout bearing.
If a bearing looks like it can't be lubed, but feels good, then I sink it in a can of oil while I work on the car, and install it again.
Old 01-21-2013, 01:40 AM   #11
Tanglfoot
You can also put the bearing in a pot of grease on the stove (when mum is away of course) and heat the grease so it fills the bearing then let it cool down
Ahooga
Tanglfoot is offline   Reply With Quote
Old 01-21-2013, 02:50 AM   #12
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Tom,
In the past, I've been able to grease some T.O. brgs with a wheel bearing packer. They have to be OFF the collar. Bill W.
"THE ASSISTANT GURU OF STUFF"
