05-03-2018, 09:05 AM | #1 |
black sooty sparkplugs
I've had a feeling that my "new " coupe was running rich and now that I find my spark plugs all black and sooty I think my suspicions are true.
What do I do about it? My GAV is totally off but I suspect it's not working correctly. Is there a test procedure for it? And/or should I first set my idle according to the owner's manual? Thanks, Carl |
05-03-2018, 09:27 AM | #2 |
Re: black sooty sparkplugs
Unless you have original jets in your carb it will run rich with todays jets. The closest to original are Renner's Corner jets. They flow test theirs and work better than the regular vendor jets. As for the idle, let the engine tell you how low to go.
Mike
1930 TownSedan (Briggs) 1957 Country Sedan |
05-03-2018, 09:45 AM | #3 |
Thanks Mike, and forgive if this is this is a stupid questions. But are you saying ignore the GAV and swap out the jets, or are the GAV and jet control one in the same?
05-03-2018, 09:45 AM | #4 |
If your GAV is not affecting your engine you have a blockage in your carb, need to clean all the ports and passages.
05-03-2018, 12:30 PM | #5 |
What plugs are you running??
Paul in CT |
05-03-2018, 01:30 PM | #6 |
Try, swapping the jets out and then play with the GAV. You may find she runs great the way mines does or you will have to open or close the GAV a little more. Hope this answers your question. Mike
05-03-2018, 01:51 PM | #7 |
Interesting. The plugs are Autolight, though I don't know which ones. What are 3X plugs? I'll look into the jets.
Thanks, Carl |
05-03-2018, 01:55 PM | #8 |
05-03-2018, 02:06 PM | #9 |
The 3x plugs are the expensive ones by Champion. they were originally designed for the Model A so are the correct temperature. The problem is they are now $30 a pop. I think the next closest is the W18(?) from Champion. I got mine from Amazon which runs sales apparently-although I have never seen them on sale.
Mike
05-03-2018, 04:43 PM | #10 |
Before you go changing parts, figure out how long it has been since you cleaned your plugs. Model A plugs foul. Simply clean them. A lot of slow driving will cause it to happen more often.
05-04-2018, 07:12 AM | #11 |
Hi JacksonIII, I just bought the car, so I don't know the last time the plugs were cleaned but I did just clean them now. I also drive on the streets of Brooklyn NY, lot's of stop and go.
I'll keep an eye on them but I might also check my carb for blockage as noted above, that GAV doesn't seem to be working correctly. |
05-04-2018, 10:54 AM | #12 |
You older guys may remember some of these signs
05-04-2018, 11:39 AM | #13 |
Those are awesome!
05-06-2018, 04:52 PM | #14 | |
Fred Kroon 1929 Std Coupe 1929 Huckster |
05-06-2018, 04:54 PM | #15 |
are black sooty spar plugs also a sign of not driving/running your engine enough?
05-07-2018, 11:14 AM | #16 | |
I know very little about the GAV - I need to investigate.
05-07-2018, 11:15 AM | #17 |
05-07-2018, 11:55 AM | #18 |
I don't know a lot about it either. Just what I found out the hard way. On one of my carbs, if you take the GAV out along with the thing it screws into, you can look down into the shaft where they came out of. In the bottom, on some carbs there is a fitting that the GAV closes into to close it down or adjust the amount of gas going through. This fitting screws out and you can replace it. On other carbs there is no fitting like this-the GAV just closes against the body of the carb. All this stuff depends on when the carb was made. Like I mentioned before some people on this site can give you a far better explanation about this subject. And also this may not be your problem but I thought I would mention it just in case.
05-07-2018, 06:59 PM | #19 |
I would start by changing the spark plugs. “New” plugs will rule out one possible problem.
Gap at 35. I have used the Champion W16Y plug for years. Around town driving, always under 45 mph. Just changed a set that were loading up, car was losing power and running poorly. It’s now running fine. I set GAV at open 3/4 turn with cold start. Than turn it down to 1/4 or so depending on how I am driving and weather conditions. Enjoy. |
05-07-2018, 07:32 PM | #20 |
Thread Tools | |
Display Modes | |
