Old 10-25-2017, 09:08 AM   #21
gweilbaker
gweilbaker's Avatar
Default Re: Got it running good but..........
Suspect the gas supply, could be restrictive, go ahead and look at the filter. If it's OK at least you can check that off your list.
gweilbaker is offline   Reply With Quote
Old 10-25-2017, 10:01 AM   #22
Licensed to kill
Licensed to kill's Avatar
Originally Posted by Tom Wesenberg View Post
That sounds like fun.. Must be a nude beach in the area.
That was a test to see if people actually read my post. You win.
Licensed to kill is offline   Reply With Quote
Old 10-25-2017, 10:02 AM   #23
Licensed to kill
Originally Posted by BILL WILLIAMSON View Post
Did you try opening the GAV, for a higher speed?
Chiefs' method was: Run at a constant 20 to 25 MPH in second & adjust the GAV for the SMOOTHEST running.
Bill Diddle
Will do. Thanks
Old 10-25-2017, 10:02 AM   #24
Licensed to kill
Originally Posted by Ray64 View Post
Someone drilled both levers on my car real shallow and glued a B B in the hole and it works perfect Don't drill to deep
I like that idea. Thanks
Old 10-25-2017, 10:03 AM   #25
burner31
burner31's Avatar
Maybe a dumb question...but are you running an air cleaner?
Keith
Shawnee OK
'31 SW 160-B
Old 10-25-2017, 10:53 AM   #26
steve s
steve s's Avatar
The last two times I saw this problem, it was caused by those cute little spring-held fuel filters that install in the sediment bowl.
steve s is offline   Reply With Quote
Old 10-25-2017, 10:57 AM   #27
Licensed to kill
No air cleaner. has the cast iron filter bowl on the firewall. Don't know what's in it though. Will remove the bottom plug and check it out. Also don't know if there is a screen in the tank.
Old 10-25-2017, 10:57 AM   #28
duke36
One temporary option for the worn quadrants is to cut a steel Revlon finger nail file to fit the quadrant and push it in to place or use some Locktite as well.
Old 10-25-2017, 11:13 AM   #29
Licensed to kill
Checked the sediment bowl and there was a screen in there and it was.......ugly. Ugly enough to restrict flow?? Don't know but certainly possible. Will replace the screen as well as check if there is a screen in the take, if not, put one in and if so replace it. It's snowing so can't (won't) test drive it today.
Old 10-25-2017, 04:07 PM   #30
Jim M
Jim M's Avatar
Tom
I haven't laughed so much in a long time. I have been reading this post and answers this week and had to read the post again 3 times before I finally broke out into a roar. It is always a good day when you get a good laugh. Thank your for your wisdom..........and sense of humor!
PS: Still haven't installed your EVR yet. A is sitting on jack stands with nothing but and engine. Got to get going and put it back together again and your laugh may "prod" me.
Jim M is offline   Reply With Quote
Old 10-25-2017, 04:19 PM   #31
steve s
steve s's Avatar
Originally Posted by Jim M View Post
Tom
I haven't laughed so much in a long time. I have been reading this post and answers this week and had to read the post again 3 times before I finally broke out into a roar. ... .
This might explain why guys only name their cars after women.
Old 10-25-2017, 04:24 PM   #32
Licensed to kill
I thought it was because of the old saying "if it has t_ts or tires it's going to give you grief".
Old 10-25-2017, 04:39 PM   #33
burner31
burner31's Avatar
Wiser words were never spoken=truism
Keith
Shawnee OK
'31 SW 160-B
Old 10-26-2017, 06:07 PM   #34
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Fur whut it's wurth??? My Avatar Car is named "VERMIN"
Bill Odd
"THE ASSISTANT GURU OF STUFF"
Old 11-01-2017, 09:54 AM   #35
Licensed to kill
So, I removed the screen from the sediment bowl and put a new one in the shutoff valve in the tank. There is still a screen in the carb. I took it for a drive and found that the warmer it got the better it ran but only marginally. I did get it up to 150 degrees at the water neck and was able to JUST get 50MPH but can feel a very slight surge like it's starving for fuel. Judging by how much the fuel goes down on the gauge, it sure aint starvin'. Timing is right on as per Jack Bahm's video and the points are set at .022 but the gap in the distributor (body to rotor) is large, about .040. Going to pull the plugs and check the colour.
