10-21-2021, 03:11 PM | #1 |
Engine Oil Drain PLug Flathead V8 1946-47-48 Engine
This looks like to be my engine oil drain plug on my Flathead. It almost looks like a cap????? Being my first time changing the oil, this Newbie needs guidance . Is this what it should look like???? I have never seen an oil plug that looks like this!
I was able to successfully change the transmission oil. Now that type of plug is what I expected to find on the oil pan. To make sure I got the correct 2.5 pints into it, i removed the shifter and poured directly into the transmission! |
10-21-2021, 03:24 PM | #2 |
Re: Engine Oil Drain PLug Flathead V8 1946-47-48 Engine
Yep-that be it!
1952 Ford F1 1965 Ford Falcon Sprint 2007 Ford Mustang GT |
10-21-2021, 03:38 PM | #3 |
I think they were made that big to be able to drain the big chunks of sludge that accumulated in the engine from using non-detergent oil.
10-22-2021, 06:56 AM | #4 |
Yup. Pipe wrench works great on it.
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it |
10-22-2021, 07:26 AM | #5 |
Thanks to all who responded! I had read that there might be rust flakes and even sand from the block! Is there any sort of a tool to use to scrape out any sludge found other than one's finger?
10-22-2021, 08:00 AM | #6 |
10-22-2021, 08:10 AM | #7 | |
Thanks Good point Have not yet changed the oil so don't know if I have a lot of sludge or not. In any case, I hope there are "videos" out there view before I take on such a project. |
10-22-2021, 08:13 AM | #8 |
I would suggest using high temp epoxy to secure a high strength magnet to the center of the drain plug. Cheap insurance to catch any metal flakes floating around in there.
Almost every swap meet, you can find an aftermarket plate steel wrenches that fit this plug. Many are "mutlitools" with sizes for brakes, etc., but one is generally for the drain plug. Last edited by Tim Ayers; 10-22-2021 at 08:54 AM. |
10-22-2021, 08:26 AM | #9 |
hey Ramblin Reck, about your eng oil drain plug, for my '37 I purchased a large 2" drive socketyou can also get a reducer so to use a 3/8"drive rachet which is alot easier than an adjustable crescent wrench or a pipe wrenchbecause your going to be changing oil quite often. more than you modern daliy drivers. just remember not to use alot of torque,snug.make sure if there is not a large fiber/paper or copper sealing washer attached to drain plug,get one. there will be some oil goobers drain out of your oil pan drain hole,warm engine good and hot then drain wright away to get alot of that sludge to drain. as far as using a tool to scrape out sludge not advisable you don't want to damage the oil pickup,which is very close to floor of oil pan.probly finger only. when i first got my '37 i changed the oil every 500mi.now about 800-1000 mi.oreillys 10w30conventional oil 3.99 a quart. hope this helps.Tom.
10-22-2021, 09:00 AM | #10 | |
Thanks I might want to get a new "washer" before I start. Also smart not to insert anything into the pan, using only a finger so as not to break something in there. All good advice. I am sure grateful that all y'all are here to guide this Octogenarian newbie. |
10-22-2021, 09:20 AM | #11 |
Be careful the first time you remove plug as the oil can come out with a vengeance. Magnet is good idea. No need to epoxy it as it will stick where you put it.
10-22-2021, 09:49 AM | #12 | |
Magnet is an aftermarket product or is it built into the drain plug? I have found some small (nickel size) and extremely powerful magnets inside of old computer hard drives that i destroyed. Should I use that? In Joe's Antique Auto catalog, the big drain plug looks concave or convex whichever is correct term. |
08-21-2022, 10:26 AM | #13 |
Can't help but ask another elementary question. How much torque? Anyone have a number? I've seen so many threads ruined by mechanics who tighten "by feel," especially oil pans.
Use a torque wrench, tighten by feel. When it strips, back off 5 ft-lb. Don't like that procedure very much. |
08-21-2022, 11:21 AM | #14 |
Ramblin Reck: farmertom's advice is well worth following. If you try to dislodge sludge particles you will inadvertently be loosening up small bits and pieces that will be free to contaminate your oil and possibly damage your bearings. Let it be until you have the time and patience to remove your oil pan.
On the 40-48 transmission there should be a drain plug on the bottom and a fill plug on the side. The same is true of the rear end differential case. You fill it with fluid until it starts to drip out of the fill plug. It is possible to change drain plug styles as shown below. I think it requires a 3/8 drive. Last photo shows rear gear ratio numbers stamped on case. You shouldn't have to remove the transmission shift cover to fill your transmission. Last edited by 19Fordy; 08-21-2022 at 11:53 AM. |
08-21-2022, 12:53 PM | #15 |
08-21-2022, 01:51 PM | #16 |
NO. Not in my humble opinion.
08-21-2022, 02:53 PM | #17 |
hey ramblinreck,i agree with 19Fordy about the fill and drain plugs in trans and rear diff. i purchased all 4 plugs new from macs or c andg.they are easy to remove with 3/8" drive extention or just the ratchet i find a 2"ext. works best. the 85 yr old plugs were some odd size so first time service for me i ground down an old 1/2"ext. to get the origs.out. Tom.
08-21-2022, 03:15 PM | #18 | |
https://www.fordbarn.com/forum/showthread.php?t=148101 More reading about it here: https://www.google.com/search?q=remo...hrome&ie=UTF-8 |
08-21-2022, 11:10 PM | #19 |
Be careful with you finger in the sump. The threaded edge can be sharp. Snug the plug just a bit past tight. If it does not leak, you are good. most of us change our own oil as the zippy-fast shops love to crank that plug down tight.
