Old 01-20-2020, 08:31 PM   #1
FrankWest
FrankWest's Avatar
Default early ford development water cooled vs air cooled
Did Henry Ford ever consider air cooled engines rather than water cooled.
It would seem that air cooled engines would be simpler, but they must run hotter causing more problems.
FrankWest is offline   Reply With Quote
Old 01-20-2020, 11:57 PM   #2
redmodelt
redmodelt's Avatar
Default Re: early ford development water cooled vs air cooled
https://www.macsmotorcitygarage.com/...le-x-8-engine/
Yes also Edison was working on an electric car.
https://www.wired.com/2010/06/henry-...mas-edison-ev/
Old 01-21-2020, 10:14 AM   #3
rotorwrench
rotorwrench's Avatar
Ford made a lot of air cooled engines during the early years for various applications but most never went into production. Ford also made a lot of air cooled Pratt & Whitney aircraft engines during the war under licence.
They put a lot of time into the X8 project before Henry finally threw in the towel on it. The V8 was a lot more practical.
Old 01-21-2020, 04:52 PM   #4
Royce P
Royce P's Avatar
Franklin was one of the best selling cars in the days before assembly lines. All of their cars were air cooled. They had a reputation of being trouble free.
Ford built a few prototypes in the early "letter car" days. No telling why, but they remained experiments that were never produced beyond the few experimental examples.
1910 Touring
1914 Touring
1915 Touring
1917 Torpedo Runabout
Royce P is offline   Reply With Quote
Old 01-21-2020, 06:53 PM   #5
FrankWest
FrankWest's Avatar
You would think that getting rid of the water jacket would make an engine simpler.
But I guess because of the increased heat maybe things wear down faster?
Old 01-21-2020, 06:55 PM   #6
FrankWest
FrankWest's Avatar
volkswagon captalized on the idea, wasn't porsche also air cooled?
Old 01-21-2020, 07:06 PM   #7
FrankWest
FrankWest's Avatar
1933 Franklin..I think it was over 3000 dollars in 1933.
Old 01-22-2020, 09:53 AM   #8
40 Deluxe
Takes a lot of air to cool an air-cooled engine which means a big fan which uses up a lot of power. Plus an oil cooler is usually used as the oil gets real hot! Air cooled VW's had an oil cooler above #3 cylinder causing it to always run hot so valves usually burned on that cylinder first.
(You'll notice that airplanes have a huge fan on front to cool the engine?
Old 01-22-2020, 03:08 PM   #9
rotorwrench
Airplanes can't stop at a stop sign so they always have air flow. Many have cowl flaps to control air flow as needed. Aircraft engines have always been under the weight controlled design for better power to weight ratio. As technology progressed, they finally found ways to use liquid cooling to a science with examples being Rolls Royce Merlin engines and Allison 1710 V12 engines. The Merlin had more power due to a built in supercharger system and the allison was stuck with turbocharging so it never gained the power levels that the RR/Packard Merlins did.
The smaller helicopters with piston engines still use a basic air cooled aircraft engine but they are modified for different fan designs with baffles to help cool things down. A lot of them have two oil coolers just to keep within limits under heavy loads. Cylinder head temperature and oil temperature gauges are required items on all of the air cooled aircraft engines.
Ferdinand Porsche was the head of the design team that developed the "peoples car" for the German Labor Front (Union) back in 1937 before Hitler went ape shit. VW, Auto Union (Audi), and Porsche have been intertwined with each other in one way or another since the war was over.
Old 01-23-2020, 12:55 AM   #10
daveymc29
daveymc29's Avatar
We had an amphib in the Marines that was air cooled. Not many produced for some reason and I never drove one. our P-5 Amphibious tractor used an Allison 1790 V12 that was converted to water cooled. Only engine problem I EVER SAW WITH IT WAS GUYS DRIVING IT WOULD FORGET TO STOP BEFORE ENTERING THE WATER AND THE JACKSHAFTS THAT RAN FANS ON THE TWO SIDES OF THE VEHICLE WOULD BREAD WHEN THE FANS HIT THE WATER. THEN I'D HAVE TO REPLACE THE JACKSHAFT UNIVERSAL JOINTS, SPARK PLUGS OFTEN FOULED IF THE VEHICLE WAS PUSHED HARD ON LAND DURING HOT DAYS AT CAMP PENDLETON.
daveymc29 is offline   Reply With Quote
Old 01-27-2020, 11:03 AM   #11
dropacent
dropacent's Avatar
Ford had an air cooled car planned in 1904. I’ve been told one was built, and think I’ve seen plans. They decided to go with water cooled instead, and produced the 4 cylinder model B. About this time, the split with the majority stockholder Alexander Malcomson took place. Malcomson went on to produce the Aerocar, using air cooled motors made in Indiana. Perhaps the split was connected to this somehow. Remember, at this time FoMoCo was an assembler, not making the parts themselves.
dropacent is offline   Reply With Quote
Old 01-27-2020, 11:09 AM   #12
dropacent
dropacent's Avatar
Air cooled ford
File Type: jpg EABA6B9B-96F0-40C6-86A7-7FDAE1DAE48E.jpg (68.3 KB, 14 views)
File Type: jpg A42CEA5D-8005-4D06-BCA6-576A93320D2B.jpg (68.3 KB, 10 views)
Old 01-27-2020, 11:10 AM   #13
dropacent
dropacent's Avatar
Air cooled
File Type: jpg 47075B32-F9B9-4272-942E-08338F61363C.jpg (68.3 KB, 7 views)
Old 01-27-2020, 02:30 PM   #14
gz
gz's Avatar
At least one air-cooled c. 1904 Model B four cylinder engine was built. The Henry Ford Museum has one but it is not on display.
gz is offline   Reply With Quote
Old 01-29-2020, 05:59 PM   #15
dropacent
dropacent's Avatar
That would be really neat to see that motor, Guy. If I can recall the conversation with LD Porter correctly, he told me he saw it, and the flywheel was at opposite ends than the production engine. Little fuzzy on that. It would be interesting to me if it may have been the same as the aerocar motor, that Malcomson ended up using.
